New Posts New Posts RSS Feed - Wood glue cleaning method?
 Post Reply Post Reply Page  <123
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 10:40pm
I clean when I notice crackle or if/when I feel the urge! I use a dust filter in the house and an anti-static gun on my records. MM/Bob is right IMO about putting clean records into a new inner sleeve.
I like the idea of a dust filter, but fear it would be defeated here. What do you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 8:43pm
Well it peeled off easily enough and certainly looks cleaner than the other side. The problem I had was where glue had got under the edge and stuck to the other side. There's still a bit I haven't managed to get off so I can't play side 1. I also had great difficulty getting off a little blob that I'm not sure where it came from.
I played the cleaned side and it still sounds dreadful. I don't know whether it's a damaged record I bought or whether it's a bad pressing. How common are / were bad pressings?
I'm tempted to buy the album (Neil Young's Harvest) on CD to see what it should sound like. Yes, I know that comment contradicts itself.
Now listening to Ogden's Nut Gone Flake - "Good God Man, he thorkus".
Edited by ICL1P - 13 Nov 2012 at 10:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 11:31pm
A household unit with cleanable filter bought in Argos. It makes a little noise so I tend to run it overnight to remove light airborne dust and fibres.
Oops, nearly missed the Ogden's reference - Mad John if memory serves.
Edited by Fatmangolf - 12 Nov 2012 at 11:32pm
Wandique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wandique Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 12:07am
Undoubtedly bad pressings exist. As long as I could find I prefer japanese pressings,
they are second to none Smile
Rust never sleeps
