Wood glue cleaning method? |
Post Reply
Page 123> |
| Author | |
ICL1P
Joined: 04 Aug 2012 Location: Faringdon, Oxon Status: Offline Points: 2397 |
Quote Reply
Topic: Wood glue cleaning method?Posted: 04 Nov 2012 at 6:44pm |
Does anyone here use the wood glue cleaning method on their vinyl? If so, how well does it work?
Edited by ICL1P - 04 Nov 2012 at 8:51pm |
Quote Reply
Posted: 04 Nov 2012 at 8:41pm |
Polyvinyl Acetate? It's not April 1st is it?
Quote Reply
Posted: 04 Nov 2012 at 8:46pm |
See applications here: http://en.wikipedia.org/wiki/Polyvinyl_acetate#Applications_and_uses
morris_minor
Joined: 27 Mar 2012 Location: Surrey Status: Offline Points: 6197 |
Quote Reply
Posted: 04 Nov 2012 at 8:53pm |
Have a look here.
A mate of mine used PVA glue successfully for quite a time. Then the brand of glue he used must have changed its formulation. The set glue didn't peel off very well at all, and the record was ruined. |
ICL1P
Quote Reply
Posted: 04 Nov 2012 at 8:56pm |
http://www.google.co.uk/search?q=clean+vinyl+records+with+wood+glue&ie=UTF-8&oe=UTF-8&hl=en&client=safari
All the references I've found specify Titebond 2 Edited by ICL1P - 04 Nov 2012 at 8:57pm |
Quote Reply
Posted: 04 Nov 2012 at 9:20pm |
Quite a few demo videos on "tube".
I would think any PVA glue would work but I'm not 100% sure what reaction it would have with the vinyl record - it may pull out more than the dirt... |
ICL1P
Quote Reply
Posted: 04 Nov 2012 at 9:30pm |
I have a second hand copy of Neil Young's Harvest that I'm tempted to try it on, but I would love to hear from anyone with first hand experience.
Post Reply
Page 123> |
