New Posts New Posts RSS Feed - Replacement HD650 cable
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 9:01pm
Enjoy the music. It's not having what you want, it's wanting what you have.
Justin122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin122 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2015 at 12:51pm
Don't think you'll find one, buy some AUdio Technica headphones instead.
Paperweight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paperweight Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 1:20am
I just ordered some affordable $1.12 a foot Mogami wire and 1/4" TRS plugs to build my own cables for the 600s and 650s. I have 3 pairs of the Cardas connectors intended for Sennheiser headphones that fit on the left and right sides. The standard cables are pretty decent but tend to break in intervals of 1-2 years. I'm hoping to have the ones I build last a little longer. If not, I have another 50 feet of cable to replace it.
Depending on headphone amp, I've always found the 650s to be overly boomy in the bass.
