Replacement HD650 cable |
Post Reply
Page <1234> |
| Author | |
gbr2004uk
Joined: 23 Jul 2009 Location: UK Status: Offline Points: 105 |
Quote Reply
Posted: 16 Sep 2013 at 9:03am |
Thanks Bob. As soon as the new cable arrives I'll try just that. At the moment, all I've got as standby are Sennheiser HDR120, wireless on a battery-recharge support stand. I think the signal is equivalent to FM radio, ie very much non hi-fi (I guess). But it's OK for casual listening, esp. non music.
Couple of impractical points about the HDR120 -- it's supposed to be good for listening while doing anything about house or garden, but it too easily falls off the head! If you bend the neck to look down, the phones slip off! Don't know why Sennheiser didn't arrange something with a firmer hold . Second point which may be intrinsic to the concept -- if you forget to switch them off after the sound signal has stopped, eg end of a broadcast, after about a minute you get a blast of white noise (or maybe it's pink) in your ears! They seemed a good buy at the time, and the fact that there are no wires is in many circumstances a bonus, but if I was going to get wireless phones again, I'd look at something else. cheers Brian |
gbr2004uk
Quote Reply
Posted: 16 Sep 2013 at 9:37am |
Update on rough-n-ready test. Naxos Music Library, Sennheiser HDR 120 wireless with and without interposition of Voyager.
I thought Mahler 5th, 2nd mvt would be a good test. By itself the HDR120 gives a very poor and hopelessly thin account of this "Mit grosster Vehemenz" whirlwind. Even with the several seconds' it takes to disconnect / reconnect with the Voyager, there's no mistaking the huge improvement, especially with the Voyager switched to Contour. It's still very much better with Flat, but with Contour it's certainly listenable-to, which is something I couldn't say for these phones without the augmentation of Voyager. (I bet with the Bitzie it would be even better, from what I've read.) Actually re the Foobar2000, don't know what I was thinking of -- this can only be used with existing files, ripped CDs etc, not with streaming sound. Yes? That's not its 'thing'. all best Brian |
tg [RIP]
Joined: 19 Jan 2008 Location: Sydney Status: Offline Points: 1866 |
Quote Reply
Posted: 16 Sep 2013 at 11:19am |
Do not know about Naxos Music Library, but Foobar can play streaming content, I have used it with a local independent music station, the L*nn streaming service and one or two others at different times. Edited by tg - 06 Mar 2017 at 12:22pm |
RichW
Joined: 21 Jan 2013 Location: UK Status: Offline Points: 1471 |
Quote Reply
Posted: 17 Sep 2013 at 1:04pm |
Hi Brian,
Regarding your HD650 replacement cable - I think you have probably done the right thing by
buying a direct replacement rather than an 'upgrade' cable.
I owned HD650s until recently & bought a StefanAudioArt replacement cable & quite honestly
found little difference.
I can't comment on the Cardas though.
I never really got on with the 650s - especially the bass & replaced them recently with 700s.
Many people like HD650s so it's just down to personal preference.
gbr2004uk
Quote Reply
Posted: 17 Sep 2013 at 1:21pm |
Even if I didn't like it, I can't afford to buy another one! But I get on with it OK. Thanks for commenting, and I'm pleased to read what you say about the cable. In an idea world, I probably wouldn't use headphones at all, I'd have a sound-proofed room with the best speakers (probably a whole stack of them) that I could afford.
As with life itself and how we live it, we have to do the best we can with what we've got -- we can't do more and we mustn't do less. The cable arrived this morning, but before I use it I'm waiting for the replacement earpads to arrive.By the way, can one just push and shove these things into the cans? The HD650 is a devil to work with, I'll say that. Even with pliers it was tough work getting the old cable out -- and experimental attempts so far to push the old earpads back into place aren't encouraging. I suppose courage and brute force are the only answer, but what a poor show! Ah well <wry sigh> Brian |
Ash
Quote Reply
Posted: 21 Sep 2013 at 3:30pm |
Brian, here is one man's comparison between the HD600 and HD650.
![]() http://www.innerfidelity.com/content/very-important-sennheiser-hd-580-hd-600-and-hd-650-page-3 |
gbr2004uk
Quote Reply
Posted: 21 Sep 2013 at 5:43pm |
Thanks N_E. I'm not at this moment sure that I necessarily want to read it, tho' I might when I think about it. I've got the 650 now, better/worse/good/bad/middling and I'm not going to get a 600.
So I'll take note of the link and save it up. cheers B |
Post Reply
Page <1234> |
