New Posts New Posts RSS Feed - PSU1 to power 24v Rega Turntable
 Post Reply Post Reply Page  <1 3456>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 6:38pm
Hi, I may well be looking to upgrade the Power supply for my proposed TT purchase which appears to run 24V.  I have browsed a little on the internet and there do appear options there R**s A*****s provide a pricey offering.  Does the item discussed in the thread provide a viable option (sorry haven't got the full spec details as yet for my needs).
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Drewan77 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 6:47pm
Hi Richard
I am still using this bespoke GSP 24v power supply & switch to run my two Rega based TTs. Superb speed stability & no audible wow/flutter or pitch issues to my ears. I suggest you contact John C if you are interested in another like this.
Let us know how you get on....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:10pm
Many thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 6:59am
Much as I hate to do this, the speed controller as described here: https://www.hifisystemcomponents.com/forum/turntable-speed-control_topic4359.html
...would be ideal for 24 volts provided it's an AC motor.
The next step in development is to have a 24 volt transformer made. Currently it only does 110/220V.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 8:01am
Thanks Graham
Will see if I can get the transaction through before looking at too much further.
Apparently has a bespoke valve PSU. (Which I don't find appealing) plus the socket one with the deck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 8:26am
It's a MRM yes? According to this they did an AC and a DC version: http://4.bp.blogspot.com/-P55VrTR79T4/T2CCB33xmDI/AAAAAAAAALw/vxrpcQE0Z8s/s1600/source+circuit.JPG
Great documentation... Cry
And you definitely want one of those?
I'm not sure if I can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardl60 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 12:23pm
I can’t access the link on a tablet so will have a look later on desktop thank you.
It is the original MRM Source with AC motor. The later S.O. Was produced more on a budget had the DC motor.
When my brother bought his from new it was superb and as it was the Luxman he moved up from it should be a known quantity so far sound goes, accepting the trade off of convenience and in some ways ease of use of the DD Luxman.
This page was generated in 0.076 seconds.
