PC Power Supply |
Post Reply
Page <1 2345> |
| Author | ||
BackinBlack
Joined: 05 Feb 2012 Location: Hinton, N'hants Status: Offline Points: 2139 |
Quote Reply
Posted: 11 Dec 2018 at 8:13am |
Some "Big Brand" streamers use a Raspberry Pi or similar Single Board Computer as their core processor, many use Arm processors as does the Pi. The software and following decoding hardware (DAC) are really the key to audio quality. The cost of trying the base RPI are minimal, basic switch mode PSU, 8GB uSD card and RPi 3B+ can be bought for around £50, much less if you use a Pi Zero. just add software, then try it as a USB feed to your Majestic. Then add whatever HAT, PSU case etc you choose. There's plenty of food for thought on the Moode, Rune or Volumio Forums. iQaudio (made in UK) and HiFiBerry also have interesting ideas. I imagine you've already looked at all those and more. It's just my view, but as Chris notes, I think commercial streamers are too limiting. Been there, done that, as they say. I have acouple of streamers that lie idle with their outdated software and limited file type handling. Ian
Ash
Quote Reply
Posted: 11 Dec 2018 at 7:58pm |
I would rather build my own computer (whatever form it may take) than buy a pre-built computer or streamer. Cost is ultimately meaningless, it's mainly marketing and consumer psychology. I'm not particularly intelligent but I do have the viewpoint of a sensible engineer and have an eye for small details. I think the RPi into Graham Slee electronics will do the MySphere 3.1 justice. It sounds superb straight out of my Sony Hi-Res Walkman playing FLAC and the FM Radio is excellent too, especially when the transmission quality is high.
cypsela
Joined: 04 May 2015 Location: Wakefield Status: Offline Points: 31 |
Quote Reply
Posted: 11 Dec 2018 at 9:55pm |
Hats off to Ian for taking the trouble to explain what a hat was. As a interested follower of the forum ,the use of abbreviations can prove frustrating to non technical members like myself. Might others consider following his lead? Edited by cypsela - 12 Dec 2018 at 1:39pm |
David
Ernie
Joined: 23 Jan 2014 Location: Birmingham UK Status: Offline Points: 430 |
Quote Reply
Posted: 12 Dec 2018 at 8:33pm |
Got 3 streamers RPi with digi pro, Sonos Connect and Cyrus Stream X Signature. Not all digital sources are created equal.
Best sound per pound RPi can’t hear any difference with files above CD (44.1khz 16bit) quality though. Most convenient Sonos, even Stevens sound wise to the RPi and been running since 2008 and still going strong with regular updates from Sonos. No sign of support ending so I feel it was a great buy. Downside Sonos doesn’t play past 48khz though this isn’t a problem with CD rips and Tidal. Sounds better since I discovered that you need to set the volume to max and fixed. Hands down winner Stream X (with Qobuz and Rips). GUI is shocking but the sound... like going from £200 amp with built in MM stage to an Accension and Proprius amps. I know which one I’d be using (or at least auditioning) with +£3k head ear speaker phones. Just saying. |
Ash
Quote Reply
Posted: 12 Dec 2018 at 8:51pm |
I will do plenty of research before making any purchases. Thanks for all of your advice.
DeadWax
Joined: 18 Jan 2014 Location: Lincoln, UK Status: Offline Points: 25 |
Quote Reply
Posted: 12 Dec 2018 at 9:36pm |
100% agree with what you say ref Sonos - used it as a streamer since 2012 and it really is rock solid. What do you mean when you say you discovered that you need to set the volume to max and fixed? |
Andy R
Lincoln, UK |
Ernie
Thanks(1)
Quote Reply
Posted: 12 Dec 2018 at 10:44pm |
Hi Deadwax,
Try it, go to settings set the volume to max and set it to fixed. Think it was Graham talking about digital based attenuation that prompted me to give it a go. To my ears (no assurance of quality) it sounds better into the Majestic using the manual volume pot.
Edited by Ernie - 12 Dec 2018 at 11:06pm |
Post Reply
Page <1 2345> |
