New Posts New Posts RSS Feed - Hints For Novo Kit Assembly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2009 at 11:38pm
Drift can be a problem in "simple" or "basic" designs where minimalist circuitry is involved because gain and bandwidth is very dependant on the few components (generally resistors) used.
However, although circuits like the Novo look simple due to the "experienced hands" of an "old-timer" PCB designer, they have similarities to early modular opamps which are designed to be stable against component drift.
example of an early modular opamp
The one pictured above is by GAP/R (later Teledyne) from 1963 and carbon resistors having the worst drift can be seen. Even so, the design was such that it would not have measurably drifted because of these.
In the Novo we use metal film resistors whose drift is as little as 50 - 75 parts per million per year (0.005 - 0.0075%) once burnt-in, and 100 - 200 ppm/year from new.
By careful component selection by which I mean buying the right parts from reputable manufacturers with a reputation to keep there should be no measurable drift, but as components settle performance improves over the normal and accepted burn-in period.
littletree76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littletree76 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2009 at 12:24am
Based on what I have read above from Graham, I suppose the Novo kit use quality discrete components with low tolerance and drift to contain variation in electrical parameters. Feedback and servo loops have been used as well to remove dependency on absolute values of components to further ensure the amplifier circuit will perform within designed tolerance and all measurable parameters meeting specifications throughout its life span ? Perhaps being built with discrete components instead of ICs helps in achieving this goal.
In this case, anyone with some basic soldering skill and understanding of electronic engineering should be able to assemble the kit and tweaking/adjustment after assemble is not necessary for it to work according to specifications. But consider the fact that I was struggling with soldering opamp in SOIC package onto Brown Dog SOIC-to-DIP adaptor recently in rolling opamp of portable headphoe amplifier, I might have to opt for commercial Novo (I studied electronic engineering about eighteen years ago).
mrarroyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrarroyo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2009 at 12:52pm
littletree76, I am all thumbs and I have burnt boards before. Unhappy Yet I took a chance and ordered the board! Sure hope I do not mess it up. Thumbs%20Up
jonclancy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonclancy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2009 at 6:01pm
...and how are you getting on with it, Miguel?
This page was generated in 0.064 seconds.
