New Posts New Posts RSS Feed - Help please - lost power cord
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2009 at 12:21am
Will do tg,
24V DC is the maximum DC voltage before the in-built regulator will start getting distressed.
If the 19V DC power supply is unregulated it means its voltage will rise off-load. Now, the load of the Voyager is no where as big as the load of a laptop so the voltage could rise too high. As usual it is best to know if the voltage is higher off-load and the only way is to measure it with a multi-meter. If it stays at 19V (plus or minus a fraction) then it will be OK. It will also mean that the supply is a regulated supply.
This page was generated in 0.064 seconds.
