Help please - lost power cord
URL: https://www.hifisystemcomponents.com/forum/forum_posts.asp?TID=471
Printed Date: 27 Mar 2026 at 6:08am
Topic: Help please - lost power cord
Posted By: aa1037
Subject: Help please - lost power cord
Date Posted: 28 Apr 2009 at 10:54pm
Hi,
I have a PSU1-24 (120V 60Hz 120 mA) and I've lost the mains cord - what do I need for a replacement? And where can I get it? (U.S)
I have a couple cords from different products that look like they'll fit and have 10A 125V imprinted on the plug - will they work?
Thanks in advance,
Aaron
Date Posted: 28 Apr 2009 at 10:59pm
Hi Aaron,
If they'll fit they're OK.
Posted By: aa1037
Date Posted: 28 Apr 2009 at 11:06pm
Thanks Graham - they work and I'm up and running!
Posted By: mrarroyo
Date Posted: 29 Apr 2009 at 1:17am
All is well that ends well, specially at no additional cost. Wink
Posted By: jlinford
Date Posted: 03 Jun 2009 at 5:12pm
Hi,
I have a similar question this time about the Voyager - can a different mains adapter be used other than the one supplied? E.g. the one that powers my laptop is 19v 3.16A output, can it be safely used?
Thanks
Julian
Posted By: mrarroyo
Date Posted: 03 Jun 2009 at 10:49pm
You need 24 vdc.
Date Posted: 04 Jun 2009 at 12:05am
From website specs -
Quote Power sources: Battery, 9V (MN1604; 6LR61), USB 5V via "mini-B" (internal analogue voltage conversion to 9VDC), AC/DC mains adapter 12-24V DC, (polarity protection on each)
Perhaps Graham will enlarge on the last aspect.
Date Posted: 04 Jun 2009 at 12:21am
Will do tg,
24V DC is the maximum DC voltage before the in-built regulator will start getting distressed.
If the 19V DC power supply is unregulated it means its voltage will rise off-load. Now, the load of the Voyager is no where as big as the load of a laptop so the voltage could rise too high. As usual it is best to know if the voltage is higher off-load and the only way is to measure it with a multi-meter. If it stays at 19V (plus or minus a fraction) then it will be OK. It will also mean that the supply is a regulated supply.
