New Posts New Posts RSS Feed - 3.5 jacks or DIN?
3.5 jacks or DIN?
Poll Question: Are 3.5mm jacks more useful in this computer age than DIN sockets?
Vote Poll Choice Votes Poll Statistics
6 [85.71%]
1 [14.29%]
0 [0.00%]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Topic: 3.5 jacks or DIN?
    Posted: 19 Aug 2009 at 11:10pm
In these days where tape recorders have been replaced by computer is there really a need for the old DIN tape loop sockets?
If a product was too small to allow phono sockets (RCA jacks) the choice would have to be DIN sockets or 3.5mm jacks.
These days almost everything comes with accessory "patch" leads having phono or 3.5mm jack plugs, so would most users even know what a DIN socket is?
Please take part in this discussion and vote for your preference.
mrarroyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrarroyo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2009 at 1:10am
Are you talking of the 5 pin DIN socket? I recall them but honestly can not see their use in the USA (home application).
mikebailey61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebailey61 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2009 at 3:22pm
I can fondly remember using DIN plugs and sockets to make my own cables to connect between radios and cassette decks long long ago. They were expensive (for a teenager paying 70s prices), extremely fiddly to hold and most attempts to solder one usually ended with me burning my fingers or completely melting the plastic that held the 3 or 5 pins in place, or didn't as was often the case. LOL
3.5mm jacks anyday.Thumbs%20Up
To err is human, to really mess things up takes a software engineer
iamalexis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamalexis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2009 at 5:29pm
are there any sound quality and reliability issues with using 3.5mm sockets. will they stand up to the same amount of wear and tear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2009 at 10:11pm
If tweaked on occasion by a twisting action to remove any oxides that could build up, and by cleaning with some alcohol cleaner prior to connection - which really ought to happen with all new connectors - then IMO they should be just as good as phono/RCA plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamalexis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2009 at 10:55pm
is there any issues with smaller surface contact? is that why you need to make sure you have a clean contact? i remember someone telling me about the advantages gpo connectors have over bantam connectors and something along these lines being mentioned...
This page was generated in 0.074 seconds.
