New Posts New Posts RSS Feed - Hi (fi) expectations
philipb31 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philipb31 Quote  Post ReplyReply Direct Link To This Post Topic: Hi (fi) expectations
    Posted: 13 Jan 2025 at 5:35pm
I have had news from JC himself that I am expecting, so to speak… my Accession is almost ready (I’m like a kid in shoe shop… wait, that’s not right) and I have ordered the Enigma to boost my joy.
As this is my first decent phono stage, and my first GS product - I can’t imagine John doesn’t include a comprehensive set of instructions and guidelines - but I wonder if anyone has any pro’ tips?
Should I leave it switched on for the first three months, do I need sunglasses when unboxing, can exposure to audio excellence make me blind?
Any personal experiences and tips greatly appreciated.
CageyH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 7:03pm
Leave it powered on 24/7.
Is it MM or MC and what cartridge are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote philipb31 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 7:16pm
MM, super, super excited!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 8:15pm
The manual is good. I'd stick with the RIAA setting till you're used to the preamp. But do check your cartridge's recommended load as the MM version lers you add more capacitance if needed. What cartridge do you use?
The sound will develop during burn-in for a couple days and mature within a week or two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote philipb31 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 8:19pm
ortofon 2M blue on an SL-1210 my 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote philipb31 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 8:26pm
…mk 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote philipb31 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 8:48pm
  • Channel balance at 1 kHz
    1.5 dB
  • Output voltage at 1 kHz, 5cm/sec
    5.5 mV
  • Channel separation at 1 kHz
    25 dB
  • Frequency response 20 Hz - 20 kHz
    20-20.000 Hz + 2 / - 1 dB
  • Tracking ability at 315Hz
    80 µm
  • Compliance, dynamic, lateral
    20 µm/mN
  • Cantilever material
    Aluminium
  • Stylus type
    Nude Elliptical
  • Stylus tip radius
    r/R 8/18 µm
  • Tracking force range
    1.6-2.0 g (16-20 mN)
  • Tracking force, recommended
    1.8 g (18 mN)
  • Tracking angle
    20°
  • Internal impedance, DC resistance
    1.3 kOhm
  • Cartridge colour
    Black/Blue
  • Cartridge weight
    7.2 g
  • Premounted cartridge weight
    16.7 g
  • Recommended load resistance
    47 kOhm
  • Internal inductance
    700 mH
  • Stylus colour
    Blue
  • Recommended load capacitance
    150-300 pF
This page was generated in 0.075 seconds.
