New Posts New Posts RSS Feed - PMC 22 with Sub
PMC 22 with Sub
RedRover7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedRover7 Quote  Post ReplyReply Direct Link To This Post Topic: PMC 22 with Sub
    Posted: 23 Jan 2023 at 11:07pm
Hi All,
New member here looking for advice. I am using PCM 22 speakers in my set up in a medium room 4.5 x 4.0 meters.
Was wondering has anyone else the same speakers and used a sub to complement these other than the VERY expensive PMC matching sub. If so what was the brand and model ? I  am thinking of BK or REL as options that may work. The PMC are super speakers in terms of clarity detail etc in my opinion.
Rest of system is SME 10A with Dynavector 10 x 5 cart, GS Gram
AMP 2 SE and Arcam A39. Also think of Accession upgrade and wondering what type of improvements I can expect over the exceptional Gram 2 SE ?
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 8:06am
Welcome aboard James. I have a similar sized room and bought a REL sub in the 1990's. Very good sub. It filled in the lowest frequencies well when I had stand mount speakers but less so when I got larger speakers with extended response. The PMC speakers I have heard had deep bass as well as the detail. In a square room of that size the acoustics are challenging as I know from years of moving and measuring the acoustics. You may find moving the 22's nearer the back wall gives some more bass extension without the hassle of a sub.
On the phono preamp I think you will be pleasantly surprised at the improvement an Accession will bring to your listening. I suggest borrowing one from the loan scheme.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedRover7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 9:22am
Thanks Jon for the reply. I think a sub might add a bit of (for lack of a better word) "presence" to the overall sound. PMC say that their own sub lifts the performance closer to the top of the range floorstaders in the range, that is the 26s. But at nearly 5 grand it's the price of an pair of pretty good floor standers in itself. Of course I am sure it's an amazing piece of kit.
Could something like a say REL T9 give me 80 or 90 percent of what the PMC does do you think ?
Mikeh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeh Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 12:07pm
If you are having problems with room effects, it's often said that a pair of smaller subs can help tame room modes. Maybe not go as low as a single larger sub but better for poor room acoustics. Having said that, I found integrating a pair of REL Tx5s with my little Harbeth P3s to be really difficult. I must have spent 6 months fiddling with settings using the REL instructions and not satisfied. I then opened up a rabbit hole and started measuring with REW (free) software and UMIK mic. This revealed how much the room was damaging the bass with my prefered speaker placement. A lot of measurements and researching best speaker positioning resulted in far better response, removing the worse of room effects. I now use dsp to integrate the subs but keep a 'pure GS' route to mains only. So I have the option to include subs for some music but to be honest even though the P3s now only go down to 90Hz, I usually prefer the clarity of mains only.
In your case with the PMC 22s, which are renowned for good bass response, I would have thought research of best speaker placement and maybe some room treatment would prove very worthwhile before spending on sub(s).
I would suggest your deck and cartridge deserve a trial with an Accession which offers such a sublime sound. Really amazing!
Innuos Zen mini mk3 streamer
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedRover7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 12:54pm
Appreciate the reply Mike. Would really like to hear the Accession. As far as I know there are no local dealers near where I live and will as Jon previously suggested,  try to pursue the loaner route. As for the sub I do fear it could lead to a " down a rabbit hole" scenario of constant fiddling so I will look at the options you suggest regarding alternative solutions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lfc jon Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 8:19pm
Hi James.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedRover7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 8:37pm
Hi Jon, Hope all  good with you.
