New Posts New Posts RSS Feed - 2nd hand and new LPs
 Post Reply Post Reply Page  123 7>
Post Options Post Options   Thanks (0) Thanks(0)   Quote lfc jon Quote  Post ReplyReply Direct Link To This Post Topic: 2nd hand and new LPs
    Posted: 13 Feb 2018 at 9:23pm
I live near Plymouth can anyone suggest a good record shop for new and 2nd hand Vinyl.As some records i would like i can't get new on vinyl or i just can't find it
Would go on line but i like to see it before, for the condition [ie 2nd hand]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Firth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 9:44pm
I use Discogs quite a bit.
Pick a seller with decent feedback, and you're sorted.
I've bought loads from Discogs, and no problems with anything I've bought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 10:11pm
I'd second Chris' experience with Discogs.
Ernie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ernie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 10:35pm
Me too. Bought stuff from Europe as well as UK without a hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 11:29pm
It is not near to Plymouth but I have been to a good record shop in Exeter a couple of times in the past, on the high street down the hill behind the Cathedral close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 11:46pm
There is (was in 2014/15) a good second hand and new record shop next to the bus station in Truro. I can't remember seeing one in the various other towns we have visited like Falmouth, Bodmin, St Ives, Launceston, St Austell, etc. but others may know better. There were plenty of charity shops with vinyl around and I think I shopped in some in Plymouth where you are!
tg [RIP] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2018 at 7:23am
Not a shop per se but I can recommend Brett Grant @ http://www.classicrecords.co.uk/ if you are looking for specific classical recordings.
I have purchased from him for a good number of years now and never had a disappointment.
