New Posts New Posts RSS Feed - Spoilt for choice!
Spoilt for choice!
Diamondmask View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diamondmask Quote  Post ReplyReply Direct Link To This Post Topic: Spoilt for choice!
    Posted: 30 Jun 2015 at 9:19pm
This time last year I bought a Rega RP3, being on a budget I bought it refurbished without a cartridge. I bought an AT95e, to get back to playing vinyl again. Now I'm looking to upgrade, but with what?
My budget is around £150, so my first thoughts are an AT440mla but now there's a 'b' option/replacement? Other options I've thought about include Ortofon 3m blue and Clearaudio Concept V2. Alternatively I could get an upgraded stylus for the AT95e!
I've also been recommended to go for a Denon DL110.
All these options will be connected to my GA2se.
What do you guys think I should do? I'm open to any other options obviously.
Thanks in advance.
RichW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichW Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 4:07pm
The Rega Elys 2 is well regarded with the RP3 & there's also the Grado Prestige Gold.
The Elys should have the advantage of easily matching the Rega arm geometry.
Good luck.
LOINER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LOINER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 4:48pm
I can recommend the Rega Elys 2 as that's what I have in my Rega Planar3 and I got mine for £100.00 and the dealer fitted it for me(mind you I think he allowed me £20.00 against the cartridge I traded in)That should leave you a couple of bob to buy some vinyl.
Also don't forget the Ortofon range they (ortofon)recommend the 2M Bronze with your tonearm
or the HOMC X5MC.I havnt heard either of these cartridges but the Ortofons are well thought of on the forum
Edited by LOINER - 01 Jul 2015 at 5:13pm
STUART
GRAM AMP 2SE
Post Options Post Options   Thanks (0) Thanks(0)   Quote LOINER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 8:04pm
Hope you are enjoying your Denon DL110 and your new Yes "Close to the Edge
STUART
GRAM AMP 2SE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diamondmask Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 12:49pm
Very much so, wish I'd stayed with vinyl all those years ago. Ironic that I'm now replacing CDs that I own with vinyl, or maybe moronic! Damn those marketing people selling us stuff we don't actually need!
DaveG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 1:31pm
Yup! Same here - I do try not to duplicate CD's but sometimes I can't resist
This page was generated in 0.084 seconds.
