New Posts New Posts RSS Feed - Genera?
Genera?
 Post Reply Post Reply Page  123 25>
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Topic: Genera?
    Posted: 20 Mar 2013 at 10:11pm
A PCB, case, and components kit will be offered at diy-audio-kits.com, plus we offer to build and test the Genera phono preamp project for all those not blessed with DIY skills
I have absolutely no known PCB soldering and kit building skills. How easy is it to acquire them?
Edited by ICL1P - 20 Mar 2013 at 10:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 10:46pm
There are video tutorials on youtube and practice improves your basic technique quite quickly. Once mastered you can build kits and make decent DIY interconnects.
It's something I've done off and on for nearly 40 years so I may not be the best person to comment on how easily you can acquire the skills, can anyone else share recent expereince on this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 10:59pm
Some simple tools, screwdrivers, small side cutters (wire cutters), a good smallish soldering iron (Antex 25watt or similar), flux and of course solder. First a little practice is needed, plenty of you-tube videos give guidance then hands on practice, a simple Velleman kit might provide this. Meanwhile order a Genera kit. Then, when it arrives, if you read the instructions, read them again and carefully follow the build instructions you'll have a Genera.
Go on, give it a try, you'll enjoy it....
Any problems, there's plenty of us willl help.
iamalexis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamalexis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 11:02pm
I didn't either but I built the Novo headphone amp kit and the Genera kit having only soldered leads before. I tried out a few cheap kits first from a well known high street electronics shop to get my skills dialled in!
Graham's kits have clear instructions, photos and all the components you need. I found it good fun and not too difficult! Give it a go, they sound great too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 7:47pm
Hi guys, thanks for the advice and encouragement. I'll start checking out YouTube and will get some cheap kits to practice on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 5:40pm
I am currently building my first ever Velleman kit. My eyesight is rubbish so it's proving to be quite a challenge. I've only burnt myself once so far.
ServerBaboon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ServerBaboon Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 5:45pm
Get yourself a magnify glass on a stand, in fact if you are going to be doing anything with cables or connectors a then desk clamp with magnify glass could be useful.
This page was generated in 0.096 seconds.
