New Posts New Posts RSS Feed - Battery power for EXP?
monty99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monty99 Quote  Post ReplyReply Direct Link To This Post Topic: Battery power for EXP?
    Posted: 22 Sep 2009 at 10:55pm
I'm thinking of experimenting with battery power for the Elevator EXP.
First off, is this a good idea? (issues of noise etc?)
Second, what about variability of volatages - I'm assuming a pair of charged up 12v lead acid batteries will put out maybe 27-28v at peak charge, and perhaps drop to 20v before a periodic charge ... can the EXP take the higher voltage, and will performance suffer unduly at the lower end?
I'm not really fussed about space or cosmetics since quite a bit of my system is a quite heath robinson anyway ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote monty99 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2009 at 11:33pm
Sorry forgot third question, normally I leave this on permanently (as Graham recommends), I assume therefore it should continue to be left on ... any issues with this (beyond more frequent recharges ...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2009 at 3:59am
I can't foresee any major problems but recharge at 22V or the internal regulator will "drop-out".
G
tg [RIP] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2009 at 5:28am
You're probably onto it already, but I think I would be using "deep cycle" type batteries in this sort of application.
That is if you are thinking SLA batteries.
