New Posts New Posts RSS Feed - Advice: phono pre for Project Debut Carbon
franz159 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote franz159 Quote  Post ReplyReply Direct Link To This Post Topic: Advice: phono pre for Project Debut Carbon
    Posted: 09 Dec 2012 at 7:23pm
Hi everybody.
I'm new into vinyl and, to begin with, I decided to buy a Project Debut Carbon, which comes with a pre-fitted Ortofon 2M red cartridge.
I'm looking for advice on the phono pre-amp: with that TT, would it make sense  to buy a Reflex-M or it would be simply "over-spec" and I should maybe look at a GranAmp Special edition?
Thanks in advance!
Franz
franz
suede View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suede Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 8:59pm
Hi Franz
I'm using a Project Debut Esprit (I think it's more or less the same as the Carbon only a few years older and with an acrylic platter) fitted with the 2m Black cartridge and using a Reflex phono stage and I'm very satisfied with my system and the results I'm getting. I suppose you could go further than that with the Reflex but right now I'm very content myself.
Two upgrades that will get you quite far with the Debut are the Speedbox and the "Motor Kit", which is basically just a round shaped belt, new pulley for this belt type and dampening gromits for the motor fastening. This latter upgrade might be standard issue on newer models like the Carbon so check wheter or not your belt is already the round kind, otherwise it's well spent £30. It gets rid of some faint low frequency rumble and I found this simple mod to give a great surge in vividity to the music overall. The Speedbox I highly recommend getting especially if you're also planning to get a good phono stage. It provides a great leap in accuracy and coherency.
If you're still unsure what phono stage to get you could always make use of the GSP loan programme and try out the Reflex, or any other stage, for yourself at home.
Best wishes
Edited by suede - 10 Dec 2012 at 9:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote morris_minor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 8:09am
+ 1 for what Johan said.
One of my cartridges is an OM40, which I use on a Technics DD parallel tracker, and the depth, dynamics and detail that the Reflex gives is really satisfying.
Plus, if you get a more exalted cartridge the Reflex will extract the best from that as well. Go for a moving coil and partner the Reflex M with an Elevator EXP and you'll have a world-beating combo Smile.
But take advantage of the loan scheme to hear for yourself . . . Wink
ServerBaboon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ServerBaboon Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 6:23pm
If you feel that the Reflex M is out of your budget you can also get the Green Version with its switched mode supply and upgrade to the PSU1 at a later date.
The Gram AMP 2SE is also excellent phono stage but the Reflex M UL is a definite step up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 9:06pm
+1 to the advice given already on the GA 2SE and Reflex M.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 10:49pm
I too would recommend that you go for the best you can reasonably afford, the Green Reflex with a later upgrade is a sensible option, but even at the other end of the scale the GA 2SE will bring you the unique GSP sound which is far superior to most other phono stages costing many times more.
Best advice is to take advantage of the loan scheme, but once you've heard the best it's difficult to resist.
BrentC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2013 at 9:34pm
Franz, not to hijack your thread - Johan do you have VTA adjustment on that Project Debut? I have a project carbon Debut Esprit and had read that the black wouldn't be a great idea given the lack of VTA.
This is really good news if you are getting the results from the black on this turntable paired with the reflex as I was leaning in the direction myself
