New Posts New Posts RSS Feed - Vinyl trouble Part 3: Boomy sound
Analog Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Analog Kid Quote  Post ReplyReply Direct Link To This Post Topic: Vinyl trouble Part 3: Boomy sound
    Posted: 23 Nov 2009 at 8:07pm
Here is Part 3 of my never-ending series of vinyl trouble: boomy sound. I also recommend Parts 1 and 2: "Excessive brightness" and "Distorted cymbals" - they are a great read.
Lately I have noticed an increasingly boomy (=bassy) sound when playing LP records. Tone controls are set to flat (=neutral, zero, 12'o'clock position). I have not made any changes to my listening room; no new furniture has been moved, added or removed.
I have not moved my speakers. They are still standing where they have always been. The rack is the same. The position of my turntable on the rack is the same. Everything is still the same. But now, even records that in the past needed a gentle bass boost, seem to have too much bass. I don't experience the same phenomenon with CDs, so I don't think the problem is my listening room.
This problem of excessive bass only started occurring in the past two or three months.
What can have happened?
Is it possible that my cartridge has suffered some kind of "damage" after riding at a higher than average tracking force for a year?
Once I tried setting the tracking force to the highest allowable value, 1.75 grams, but the sound became too boomy, so I put it back to 1.65 grams, which balanced the sound again, but now lately I am hearing too much bass, even though the tracking force is the same.
Any suggestions?
Edited by Analog Kid - 23 Nov 2009 at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 8:09pm
OK. The only way we can assist you is if you can post every nit-picking detail of your set-up - photo's and all (not glam shots).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Analog Kid Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 12:12am
I completely forgot about this. Will upload some pictures soon.
Is it not possible that the cause of the boomy sound (excessive bass)
is a result of the rack and turntable being poorly isolated, causing
bass vibrations from the speakers reaching the record/needle interface
through the floor and rack, thereby disturbing the stylus motion?
It seems like the most probable theory, because I don't have
this problem of excessive bass when listening to cassettes and CDs.
Edited by Analog Kid - 29 Mar 2010 at 12:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 5:07pm
@AK: there seems to be something wrong in your system, doesn't there?
First it's excessively bright, then distorted, now boomy.
Whatever item it is, it seems to have a big fault.
We would be happy to check out if it's our preamp.
Would the other makers do also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Analog Kid Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 6:19pm
I highly doubt my problems have anything to with my phono stage.
The Reflex has been a big improvement for me, over the built-in
phono stage of my Technics amplifier.
The brightness I hear is most likely caused by my Audio-Technica AT150MLX cartridge.
Looking at the included frequency graph, a +2.5 db rise is noticed between 15 kHz
and 20 kHz. Even my dealer who installed the cartridge admitted that Audio-Technica
cartridges tend to sound bright. Besides, the excessive brightness is mostly on
hard rock and metal records, a genre that is naturally mastered bright. I also
have many records that don't sound bright.
The sound of my vinyl playback was not always boomy, so it can't have anything
to do with the Reflex. My turntable, Pro-Ject RPM4, is a low-end 400 euro model.
The turntable base and platter are only 2.5 cm (1 inch) thick each and are made of
cheapish MDF (Medium Density Fibre). Back in February 2008, a few months before
I purchased my Reflex, I had the original rubber turntable feet replaced with special
spikes that are a sandwich construction of wood and rubber rings. Also got a new
rack around the same time, which has the rack columns filled with sand, to reduce
vibrations, apparently to no avail.
I tried to move my speakers further back towards the wall, which helped a tiny bit.
Maybe you can provide me with further suggestions based on the pictures of my
system and listening room.
Edited by Analog Kid - 29 Mar 2010 at 6:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Analog Kid Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 6:51pm
My speakers are about 2.5 metres apart.
They are placed about 25 cm from the back wall,
facing towards a central listening position at a slight angle
(forming a triangle).
Meaning, they are not placed perpendicular to the back wall.
Each speaker sits on four small rubber knobs.
The floor consists of hard tiles. There is a large carpet covering
most of the living room floor. However, the equipment rack sits
on an un-carpeted part of the floor as you will see in the photos.
12 photos of my system and listening room:
http://i39.tinypic.com/345o2ad.jpg
http://i41.tinypic.com/11av42r.jpg
http://i40.tinypic.com/fvlmqh.jpg
http://i44.tinypic.com/a9smkl.jpg
http://i43.tinypic.com/29e50za.jpg
http://i39.tinypic.com/maf447.jpg
http://i44.tinypic.com/2dad4c3.jpg
http://i41.tinypic.com/etf6kh.jpg
http://i43.tinypic.com/28btwr4.jpg
http://i41.tinypic.com/rh04nc.jpg
http://i40.tinypic.com/254vdxw.jpg
http://i39.tinypic.com/ra3nmt.jpg
Edited by Analog Kid - 29 Mar 2010 at 6:59pm
Cyreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyreg Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 9:42pm
Hi AK, to start with I would get the turntable back in its original as possible state.
That means also loosing the heavyweight on top of the turnplatter I suppose?
Try it on the same spot, but thereafter I would try the TT on a seperate small table.
And it's not always the right way to try redesign TT setups and......
certainly not all TT 's are heavyweights! Some choose for light and rigid! Goodluck.
TecnoDec/RB250/MP110>GramAmp2C/PSU1; Cyrus CD8SE; > Exposure 3010S2D INT > Harbeth C7ES-3 '35th Anniversary'
cabling: IC 2x DNM V3; LScable Exposure DMF-two; Furu TP60 + MWaY and BlackCable pc's
This page was generated in 0.082 seconds.
