Valve questions from a total numpty |
Post Reply
Page <12345 6> |
| Author | |
Quote Reply
Posted: 06 Jan 2016 at 4:49pm |
I take all the avove back! The amp's a charlatan!!!
Just read the description: Hybrid! A solid state amp with valves that might be doing something but definitely not power amplification--the dead give-away being its weight: 1.7kg. Not much iron then in its two (stereo) output transformers?? Doubt if it has output transformers, and if not it'll be a little class D solid-state amp. ![]() I'd just like to add that I respect good valve designs, but have much contempt for people using valves for marketing hype, especially when the valves are just for show, and from my discussions with my good friend Bob I took it that he really thought he'd bought a valve amp. Edited by Graham Slee - 06 Jan 2016 at 6:32pm |
BackinBlack
Joined: 05 Feb 2012 Location: Hinton, N'hants Status: Offline Points: 2139 |
Quote Reply
Posted: 06 Jan 2016 at 6:34pm |
To be fair, Bob did say that it had a valve preamp.
tg [RIP]
Joined: 19 Jan 2008 Location: Sydney Status: Offline Points: 1866 |
Quote Reply
Posted: 06 Jan 2016 at 7:22pm |
That's a relief, thought I might be banned for using illicit substances for a while there Bob, small signal valves such as your hybrid uses for preamp duties have, as already noted, a fairly long life, likely years of light use such as a few hours per day. Best not switched on and off too often or run for short periods. A couple of times a day should be fine, leave it on for at least an hour or so when you do use it, it will usually sound better after a little warm up time anyway. Might be worth finding out what valves it runs and getting in a set of spares. Changing them over is not difficult, nor should they require any adjustments to be made when doing so. A gentle rotational rocking can be helpful in removing them, when replacing them a careful inspection of the socket and the valve base will show the correct orientation. Bias adjustment (on amps that do require it) is usually only for power valves not preamp valves. Edited by tg - 06 Jan 2016 at 7:23pm |
morris_minor
Joined: 27 Mar 2012 Location: Surrey Status: Offline Points: 6197 |
Quote Reply
Posted: 06 Jan 2016 at 7:34pm |
Thanks Tony.
Whether or not these valves do anything, is, for me immaterial. I didn't buy it wanting a "tube sound". I wanted a bluetooth enabled amp with two inputs. This fitted the bill and I got it cheap. My questions were about looking after the valves, since if they fail I suspect the amp will fail too. If it still works, then the light show is just that - a light show. ![]() Whether or not the company is trying to pull a fast one is something that irks, (and certainly irks Graham!), but TBH I don't really care from a practical point of view, and my money didn't go to the company . . . I only considered it after figuring out that a Novo upstream would provide excellent listening, with the speakers used for TV sound and occasional casual music - most likely from Spotify via my phone and bluetooth. So a quality amp would be wasted.
Quote Reply
Posted: 07 Jan 2016 at 6:39pm |
TBF it is quite pretty to look at...
morris_minor
Quote Reply
Posted: 08 Jan 2016 at 8:10am |
morris_minor
Quote Reply
Posted: 22 Jan 2016 at 11:07am |
Will this work in my amp?
Post Reply
Page <12345 6> |
