New Posts New Posts RSS Feed - Gram Amp 2 SE channel volume
RobD67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobD67 Quote  Post ReplyReply Direct Link To This Post Topic: Gram Amp 2 SE channel volume
    Posted: 17 Nov 2024 at 6:35pm
Hi all. I recently picked up a Gram Amp 2 SE with the PSU1 for a great price.
After using it for around a month, I decided to upgrade the capacitors and try some different op amps. Changing the caps for same value and voltages, from Audio Note, Elna and Toshin Jovial and try out some op amps, like the AD823 - I found it sounding fantastic!
However, as I was listening I found that the left channel is quieter than the right? I put the original op amp back in, no change.
Could it be a bad solder joint on one of the caps? Does anyone have a picture of the back of the circuit board so I can check everything is right? It's a REV 3 board, dated 2009. Has 2 grey wires on the back.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobD67 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 8:34pm
FIXED!!! Must have been a dodgy solder joint somewhere. I retouched up every solder joint and swapped out those short bits of cable just for good measure. Just tried it now and full volume on both channels is now restored. Phew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobD67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2024 at 9:12pm
Got the upgrades finished. Turns out the Toshin Jovial caps are not very good, so all the caps are now all Audio Note and Elna Silmic 2. The op amp is the AD823, the amp now sounds fantastic!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2024 at 6:59pm
Interesting. I also like experimenting with parts but found the sound is different when they are new as 'burn-in' takes time. Please could you let us know how your replacement caps compare to the original ones after a couple of weeks powered up. May I also suggest trying a swap back to the original IC for comparison.
patientot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patientot Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 7:35pm
OP may want to peruse old threads. IIRC, GS was not a fan of swapping components. Components were chosen for a reason, especially the op-amps. FWIW I also don't know if OP's unit was pre or post redesign...IIRC there were some changes at some point on most of the GS phono stages.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 8:22pm
Agreed. Graham warned that changing the sound didn't mean it was better, simply different. Some changes to parts made the circuit less stable so sounding interesting but less accurate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 7:38pm
Rob, they are your ears, it is your money and your opinion. However your ears are subjective not an objective reference.  Your last post plugging replacement parts is not what the forum is here for so I have hidden it for now
Edited by Fatmangolf - 04 Jan 2025 at 7:40pm
This page was generated in 0.155 seconds.
