New Posts New Posts RSS Feed - Splitting a balanced connection
Ernie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ernie Quote  Post ReplyReply Direct Link To This Post Topic: Splitting a balanced connection
    Posted: 12 Dec 2023 at 6:11pm
Evening all,
I want to integrate a sub into my system. I use a Majestic as a preamp with Lautus balanced cables out to Proprius amps mounted on my speakers.
I could use the high level speaker output from the Proprius to drive the sub but this drapes cables all over the place and looks a bit crap.
Was wondering if I can split the balance cable? I’ve seen some splitter cables TRS to two female TRS allowing for two pairs of balanced lines to come out of the back of the Majestic.
I then have to find cables for TRS to RCA to input to the sub. Anybody tried this or maybe biamping from the Majestic?
I don’t want to degrade the signal to the Proprii or damage anything.
Mikeh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2023 at 10:30pm
I had my Majestic modified by John C to make the phono output variable in the same manner as the balanced out. This is an option when purchasing a Majestic.  It means I can take the balanced output to the Proprius feeding the main speakers and use the phono output for powered subwoofers. I actually have a Minidsp between the Majestic and subs to give control over room effects but that is entirely optional.
Not sure if this answers your question but it might give an alternative to working with split cables.
Innuos Zen mini mk3 streamer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ernie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2023 at 10:42pm
Yes considered this, wish I’d ordered a variable one in the first place. Wonder if John would consider doing this mod for me? I did make an enquiry some time ago but never heard anything back.
I’ve been looking at the miniDSP devices too. Dirac seems an interesting idea as well.
This page was generated in 0.077 seconds.
