New Posts New Posts RSS Feed - Spatia cable
Spatia cable
Oakrack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oakrack Quote  Post ReplyReply Direct Link To This Post Topic: Spatia cable
    Posted: 12 Dec 2018 at 6:58pm
 I have just acquired a naim Nait 2 integrated, can I use my 3 metre pair of spatia cable, or do I have to use naim cable. Hopefully you can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 7:17pm
Spatia speaker cable has been developed to be very low capacitance and should therefore be safe for use with your amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oakrack Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 7:29pm
a big thank you for the prompt reply, I have been a little worried about having to lose the spatia, it has been in my view a wonderfull cable and does sound or rather doesn't sound but just does not stand in the way of any frequency. Just a gem and one that gets a huge recommendation from me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morris_minor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 3:25pm
The Spatia cables were a revelation when I installed mine. I'd always been a bit of a cable sceptic - but these blew me away!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2018 at 3:29pm
Seconding Bob's comments, I had bought the highly regarded Tel***m Q Black cables a few years ago then I heard the Spatia cables and upgraded to the latter as they are so transparent and musical.
This page was generated in 0.059 seconds.
