 Post Reply Post Reply Page  <1 13141516>
Post Options Post Options   Thanks (1) Thanks(1)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:58pm
Embarrassed
Hands up. It shouldn't be doing that (Houston, we have a problem).
Transmitters are the usual culprit, or to put it another way, I am at a loss to design something so sensitive that will ignore strong RF.
There is a reviewer who lives under the Crystal Palace transmitter who has a similar problem.
In most cases (there aren't that many - honest), something like a DECT phone is found nearby, which swamps the input of the EXP with more RFI than it can handle.
If all else fails, we have great aftersales customer service which will refund on request or offer any alternative you wish for.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 10:57am
John C says "power-line adaptors?"
patientot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patientot Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2020 at 8:41pm
Heard of powerline internet causing all kinds of problems in audio systems...
nemu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nemu Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2020 at 4:54pm
I also had problems using powerline adapters, so I banned them completly.
Accession MM (PSU1), Accession MC (Enigma PSU1)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 7:45pm
Quick question about the PSU1. Might be a silly question but I would rather double-check than assume.
The stock PSU1 that came with my Majestic DAC is just the same as any of the other PSU1 that come with other Graham Slee products, right? Only the output cable is different, yeah? So when I get the Enigma, I will be able to advertise the stock PSU1 for sale as usable with any of Graham's 24V products?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 8:43pm
I think you are right Ash but it's best that Graham or John confirm it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 9:03am
Correct
This page was generated in 0.089 seconds.
