New Posts New Posts RSS Feed - Platter speed adjustment on B&O Beogram RX2
BagsGroove View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BagsGroove Quote  Post ReplyReply Direct Link To This Post Topic: Platter speed adjustment on B&O Beogram RX2
    Posted: 13 Mar 2025 at 9:50pm
Anyone know if there is an intrinsic speed control mechanism that can be adjusted on the RX2? I think mine is a bit fast when comparing pitch of streaming versions of same content seems to be a tad higher to my ears. I haven't yet done the strobe thing and don't really have equipment to do it. Would like suggestions re that as well.
Thanks all,
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 3:18am
check out this strobe disc available from Walmart… made by Hudson Hi-Fi.
I use a similar strobe disc made in 1960’s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Firth Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 8:11pm
Many years back I had an Ariston Q-deck that ran fast, it was even better at the right speed. A strobe and disk is a good investment and quite cheap nowadays as the helpful links above show. Please ask if you want any further help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 8:07pm
There is a service manual for the RX on Vinyl Engine. It is free for any registered user. That may be helpful if the strobe shows the speed is incorrect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 8:59pm
  I got that for Jim and sent it to him on March 14th.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BagsGroove Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 9:01pm
And thanks!!Smile
