Open Baffle Mark Audio project |
Post Reply
Page <12345 6> |
| Author | |
ICL1P
Joined: 04 Aug 2012 Location: Faringdon, Oxon Status: Offline Points: 2397 |
Quote Reply
Posted: 05 Feb 2017 at 7:37pm |
Who's Chris? |
Quote Reply
Posted: 05 Feb 2017 at 8:20pm |
Indeed I should have written Andrew as you clearly realised Ifor.
Drewan77
Joined: 25 May 2013 Location: Chester,England Status: Offline Points: 1544 |
Quote Reply
Posted: 08 Feb 2017 at 9:50am |
Just spent a couple of evenings on this - progress so far:
Frame construction with Alpair 7 baffles at the correct angle for seating position head height. The wooden side runners may prove to be rather flimsy when I try to move the finished speakers - I will have to be careful. Fastening hardware is stainless steel including nylock nuts (at the moment I'm using temporary wing nuts & square nuts until I'm satisfied everything fits).
Baffle mounting screws are held in place by small rubber O-rings so that panels can be fitted from the front. There are also decoupling spacers between baffles & frame (I intend to leave the bottom baffle/driver in place when moving these & maybe the top one as well if it's manageable).
Threaded inserts fitted to baffles for the four 15" drivers can be seen in the image above. The Alpair packaging included front mounted self-cutting bolts which is a neat touch. These will fit flush to the front rebates. Soundcare SuperSpikes used as mounting feet, fitted to M6 threaded inserts. The feet are internally decoupled which also allows easy tilt adjustment. I have taken the precaution of snugging up several nylon cable ties around the timber at the base as I suspect this may be a weak point. I will trim these later.
Rear uprights with speaker terminals mounted on wooden plates:
Aluminium side braces cut, angled & drilled at the front end only so far. I found that bending these to 45deg weakened the aluminium too much so I'm unable to fold round behind the rear support, These will have to be bolted through from the sides using threaded inserts angled into the wood. It's probably going to be fiddly so I'll start by assembling these with wood screws and if everything works, drill out & glue threaded inserts in place so hex head bolts can be used.
Edited by Drewan77 - 08 Feb 2017 at 9:55am |
Richardl60
Joined: 04 Nov 2014 Location: Yorkshire Status: Offline Points: 1475 |
Quote Reply
Posted: 08 Feb 2017 at 2:18pm |
Impressive!!
Quote Reply
Posted: 08 Feb 2017 at 10:53pm |
Very good styling IMO. |
Drewan77
Quote Reply
Posted: 09 Feb 2017 at 7:55am |
Last night I finished off the angled runners for the top baffle, started to align the side braces to the front uprights & locked the bottom baffles into place on each speaker. I also found a solution for bolting to the rear support.
Clamping the angled sections in place, then drilled, glued & screwed:
Initial assembly of the side braces (after 'negotiation' to be able to use the kitchen table, more decorating this weekend I'm afraid
Baffle mounting bolts with decoupling spacers. These will also hold the bolts in place whenever I remove a baffle.
It occurred to me that rather than try to bolt the side braces with a gap to the rectangular rear support, I could use my cutting table & strip this back to the correct 35deg angle - a sort of 'bring the mountain to Mohammed' solution (bring the mounting to more-angled….sorry). Made a small test piece and held it roughly in place so it looks like it will work. It's going to be important that when a baffle is removed, the side braces don't exert pressure on the front uprights to push them apart or inward. All the baffle bolts need to slide easily back into the original holes when reassembled during measurement.
An approximate image of how a final speaker will look (bottom braces resting on a wood offcut). The rear support will be cut down to finish flush with the top side braces. When I triangulate this, the speaker terminals will have to face forward as in the picture. Not a big issue to me.
As the main load bearing braces are double thickness, I next need to remove these and araldite/clamp together before trimming to length/drilling the rear holes. As I only have 2 large clamps and there are eight of these, this may take a few days. In the meantime, I will get 2 more timbers for the rear uprights & trim them to angle & length. I will keep the originals 'just in case'. |
Ash
Quote Reply
Posted: 10 Feb 2017 at 11:27pm |
Great photos Andrew. I could make something along the lines of a mini version of this for a 12P/12PW pairing that'll sit neatly on a desktop.
Post Reply
Page <12345 6> |
