New Posts New Posts RSS Feed - Networking help required
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Topic: Networking help required
    Posted: 16 Apr 2016 at 6:50pm
I need advice.  My Raspberry Pis, TV, AVR, YouView etc are all connected to my home network via Devolo Homeplugs.  This has worked reasonably well with just the occassional dropout of music and frustrating slow iPlayer etc through the YouView box.
I now have a problem.  With the kitchen work that we've had done the electricians have "tidied" things up a bit.  This has resulted (I think; will check in bit when the kitchen fitter goes home) in the iMac (where the music files are), the modem and the Airport Extreme being on a different trip circuit than the Pi, TV etc resulting in poor to non-existent communication between the Devolos in different rooms.
Any suggestions as to how I could "fix" the problem.  I could possibly, with a lot of work, get one ethernet cable from the Airport Extreme to the sitting room.  If I did this could I plug it into some sort of hub that everything else could plug into?
As you will realise, I have no idea about networking, and I'm not sure who to call in to sort it.  What does one google for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Firth Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 10:19pm
PM me with your phone number, and I'll give you a bell.
It will be a lot easier to talk through your network issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 9:37am
Will do. Thanks Chris.
This page was generated in 0.096 seconds.
