Home made power cable |
Post Reply
Page <1 456 |
| Author | |
Quote Reply
Posted: 25 Nov 2015 at 10:20pm |
Hi Dave, I may be able to help by applying the advice graham gave me. Do you know what material your cable insulation is made of? If not can you tell me the manufacturer details so I can find out. Either way I can work out how far from the mains plug to fit your ferrites and you can try it.
Quote Reply
Posted: 25 Nov 2015 at 10:53pm |
I'm sure the above would work better if the mains socket was an earthed metal clad type which acts as an enclosure. And if the supply to it was a radial steel wire armoured cable direct from the fuse-board/consumer unit. It would make more sense.
FAT2BIKER
Joined: 03 Sep 2015 Location: Wirral Status: Offline Points: 79 |
Quote Reply
Posted: 26 Nov 2015 at 3:32pm |
Jon The power cables are just standard, as you would get with any electrical equipment,1.8 metres in length. Speaker cables are Van damme uplcofc 4mm, 2metres in length. Hope that helps. Cheers Dave
Edited by FAT2BIKER - 26 Nov 2015 at 3:37pm |
FAT2BIKER
Quote Reply
Posted: 26 Nov 2015 at 3:38pm |
Thanks Jon Cheers Dave
Post Reply
Page <1 456 |
