New Posts New Posts RSS Feed - Home made power cable
 Post Reply Post Reply Page  <1 456
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 10:20pm
Hi Dave, I may be able to help by applying the advice graham gave me. Do you know what material your cable insulation is made of? If not can you tell me the manufacturer details so I can find out. Either way I can work out how far from the mains plug to fit your ferrites and you can try it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2015 at 10:53pm
I'm sure the above would work better if the mains socket was an earthed metal clad type which acts as an enclosure. And if the supply to it was a radial steel wire armoured cable direct from the fuse-board/consumer unit. It would make more sense.
FAT2BIKER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FAT2BIKER Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 3:32pm
The power cables are just standard, as you would get with any electrical equipment,1.8 metres  in length.
Speaker cables are Van damme  uplcofc 4mm, 2metres in length.
Hope that helps.
Edited by FAT2BIKER - 26 Nov 2015 at 3:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FAT2BIKER Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2015 at 3:38pm
Stuart is right. This thread includes Graham explaining to me where to fit the ferrite on one of my mains cables and may help you.
Mains cable ferrites
Thanks Jon
This page was generated in 0.069 seconds.
