New Posts New Posts RSS Feed - Help with Genera
Help with Genera
 Post Reply Post Reply Page  <12345 6>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 6:49pm
The easiest way to methodically check all the resistors and capacitors is the full colour PCB photo Graham includes in the manual. Assuming your copy is lost please use the schematic Graham linked to earlier in this thread and tick off each part value as you check it on the actual PCB. (There are also PCB photos on page 8 of the DIY project thread Graham linked to earlier)
Being helpful but risking stating the obvious the capacitors have their values written on the casing. Check everything including polarity of electrolytics. The resistor colours will be in 5 bands:
0-Black, 1-Brown, 2-Red, 3-Orange, 4-Yellow, 5-Green, 6-Blue, 7-Violet, 8-Grey, 9-White. 4 digits for the value with a power of ten at the end.
Edited by Fatmangolf - 19 Apr 2014 at 6:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 6:56pm
Here's a photo of mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 9:26pm
If everything has been assembled correctly then somebody here must have put in the wrong value somewhere. I could only tell that by seeing a full colour photo of the component side of the board.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 9:32pm
Graham, I was only suggesting that a possible cause could be that the 390 and 390k resisitors might have been mixed up during assembly by Mick.
Photos would help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 9:49pm
Mick, please can you take a well-lit digital photo of your Genera's PCB, as square on as possible ideally a close-up macro shot so we see the parts clearly. Ideally it would have the correct white balance, so please use a lamp and set your camera's white balance so the camera screen looks like what you see.
Please post it here as a jpg for Graham to look at. Please PM me if I can help you on the photo/upload stuff.
mickmack926 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickmack926 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 9:55pm
Graham I will try to have a detailed photo up this evening and please rest assured, I am not blaming your equipment, I understand that it is definitely me that has done something wrong, I just need to work out what it is.
Michell Gyro SE, TechnoArm A, Goldring 1042, GS Genera, DAK Novo Headphone Amp, Cyrus Stream XP₂ Qx, Cyrus CD8SE2, Cyrus PreXP, Cyrus 8 Power, ProAc D18's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 10:08pm
Photos would help.
True: if swapped it would lead to a bass and midrange free extremely thin sound with hardly any gain. Worth checking...
390 R is orange, white, black, black, tolerance band
390 k is orange, white, black, orange, tolerance band
This page was generated in 0.075 seconds.
