New Posts New Posts RSS Feed - Help with Genera
Help with Genera
mickmack926 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickmack926 Quote  Post ReplyReply Direct Link To This Post Topic: Help with Genera
    Posted: 18 Apr 2014 at 1:10pm
Hi all, I built the Genera around Christmas in anticipation of a new deck. My deck has just arrived and been put together, however the Genera is acting like a pass through (led is on but red), no amplification what so ever! I think I've thrown out all of my instructions/information, especially any test points and voltages. Would it be possible to have the instructions emailed to me graham? Or if anyone can tell me straight away that I've done XX wrong, please don't hesitate to tell me............I can put up with gloating as long as get up and running.
Michell Gyro SE, TechnoArm A, Goldring 1042, GS Genera, DAK Novo Headphone Amp, Cyrus Stream XP₂ Qx, Cyrus CD8SE2, Cyrus PreXP, Cyrus 8 Power, ProAc D18's.
tg [RIP] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 2:03pm
Mick,
perhaps if you check the photos in this thread you can compare to what you have built.
Pay particular attention to the way the opamp is inserted in the socket, it could be reversed.
The led should be red so that part is OK.
Cannot help with check voltages etc. - Graham is the man for that.
I assume you do have the cables in and out in the appropriate sockets.
Otherwise best wait for the cavalry. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickmack926 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 3:36pm
Thanks for the reply Tony, I have checked my Opamp with those pics and mine is the same, good to hear that the LED should be red too. Waited 7 weeks for my deck to be built and delivered and now my phono stage doesn't work.........gutted! I can hear a record playing (at a reasonable level) with my amp on full volume, but am worried in case the phono stage decides to kick into life and blow my speakers.
Will have to wait on Graham I suppose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 4:00pm
OK, but a bit more trouble shooting.
Since nothing has gone bang and the power led comes on, I think it is probable that you have all the electrolytic caps and the power diode the right way round.
That leaves the most likely things as either a dodgy solder joint or a solder bridge connecting two points that should not be connected.
To check that will require removing the board from the case, if you can take one or two good photos of the solder side of the board and also the top side for a sanity check and post them in this thread, someone may be able to spot a possible problem area.
I feel for you, really disappointing when you wait weeks and then stuff doesn't work.
Still, it is worse if you turn it on and let the magic smoke out.
Edited by tg - 18 Apr 2014 at 4:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 5:04pm
Photos would be good. The fact that there is some sound is also good. Don't despair, and as TG said you haven't let the magic smoke out, so all is not lost.
Do the cartridge, leads etc work with another phono amp or integrated amp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 5:51pm
As both channels are not working it should be either the voltage of 18V missing at op amp pin 8 (the pin right of the central identifier notch - by the way pin 1 is left of the notch next to a dimple), or no bias at junction R11/R12. If there is 9V here then check pins 3 and 5 of the op amp - with a high impedance multimeter they should read just a bit under 9V. If all measures correct then you should have 9V on pins 1 and 7 (op amp outputs). If so then you may have the turntable plugged to the output and the input going to your amp....
If there is no bias at junction R11/R12 then check you don't have dry joints on these resistors. If you don't have 18V at pin 8 then check for dry joints on that IC socket pin and the voltage regulator pins - if the voltage regulator output pin (goes to R14) is shorted to its centre pin, re-melt the solder so it isn't shorted and it should be working.
If you've been really unlucky you may have shorted op amp socket pins together with solder blobs.
Another thing to check for is bent up op amp pins. If all the pins were not perfectly aligned with the socket hole centres, then on exerting pressure to plug home a pin could have bent up and away, not making any contact. In this case it would be pin 4 or pin 8 (or both...).
Then again, knowing how things go in electronics, it may be none of these, but we usually get there in the end, even if it means return to base (but that has a cost to it so let's persevere Wink)
The circuit diagram with reference voltages is shown here: http://audio-forum.gspaudio.co.uk/phono-preamp-project_topic745_post5723.html#5723
Edited by Graham Slee - 18 Apr 2014 at 5:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickmack926 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 11:45am
Thanks all for the replies. Graham all my voltage measurements are correct, I have swapped PSU's with my headphone amp just in case (clutching at straws now). I have checked input/output connections, these are the correct way round. Is there anything else I can try?
This page was generated in 0.086 seconds.
