New Posts New Posts RSS Feed - Help with a pre-amp
Help with a pre-amp
 Post Reply Post Reply Page  <1234 8>
Andy9672 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy9672 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2009 at 10:16pm
You could aslo look at the Pro-ject range, they make a passive preamp that has had a lot of praise for the price
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 4:23am
This community is paid for by the proceeds of Graham Slee Projects Limited and as such has a policy of not allowing the promotion of other brands that could be classed as competitors. If a member wishes to let another member know such things the private messenger service provided for free by us to members should be used.
No other manufacturer's forum I am aware of would allow promotion of a competing brand.
Admin.
Edited by Graham Slee - 09 Aug 2009 at 4:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy9672 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 5:55pm
Sorry Graham i didnt realise you made a pre-amp (other than your great phono amps).
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy9672 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 6:04pm
Sorry again Graham, just re-read your post, though i wouldn't class them as competition though.
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 9:38pm
All is forgiven in that case Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 9:48pm
Just designing one hopefully to launch in the Autumn partly in response to this topic.
I've been often asked for a box that does "single-sided" domestic in to balanced out.
Or in this case a volume control with same.
And often requested to simply do a two or three input preamp.
It would seem there is room in the market for an absolutely-no-frills "little box" preamp, and there are passive ones, but often some gain (amplification) is required for matching a low output to a high input power amp - plus, balanced cannot be done passively.
And seeing that used to be my daily "bread and butter" job some 16-20 years ago...
One or two loose ends to tie up and I'm on to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy9672 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2009 at 10:07pm
i always wondered if you could increase the gain using a transformer bassed passive preamp.
I did think of going down the passive route but got a pre amp with the power amp i found. Looked at a ladder design volume control and thought you could do a balanced version with this?
Solo psu1
Rega Apollo
AT W1000
Technics SL1200
