New Posts New Posts RSS Feed - Help please - Audiomods 6
 Post Reply Post Reply Page  <1 121314
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2021 at 8:24pm
Have you got a cable in mind Ifor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2021 at 10:21pm
I need it to be very flexible and was thinking of something from Scotland.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2021 at 10:29pm
It has been quite a journey from the days when you first stripped down the 75 to the finished article. Hope you manage to get the cable soon so that you can enjoy the sound.
Just a thought on setting the bias pulley, is it possible to set the arm at mid arc of the playing surface then adjust the support block for the bias weight threaded arm to be level.
Happy Listening - soon!
Yes, it has been a while, but I have used it with an RB301 and was pleased with it. I like your idea of level at mid-point; why didn’ti think of that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2021 at 10:54pm
At least two good options come to mind Ifor. Look forward to seeing the new cable nearly much as you want to hear music through it.
This page was generated in 0.083 seconds.
