Headphones sound harsh with Reflex-M, suggestions? |
Post Reply
Page <12345> |
| Author | |
CageyH
Joined: 30 Apr 2012 Location: Toulouse, Franc Status: Offline Points: 1751 |
Quote Reply
Posted: 30 Mar 2020 at 4:43am |
I would say they are “medium” impedance. Some headphones are around 600 ohm.
I had a Reflex M with a Solo UL and it sounded really good with my Sennheiser HD650.
European loan coordinator, based near Toulouse, France. Funkified SL1200 Mk.II, BB3, Firebottle Kin , ADI-2 DAC FS, Modulus 686, PD-S703, Solo UL, Triangle Antal EZ |
DT999
Joined: 07 Jan 2020 Location: Australia Status: Offline Points: 95 |
Quote Reply
Posted: 30 Mar 2020 at 6:03am |
Thanks, I see there are a few open and semi-open back headphones with 600 Ohms, but I can't find anything like that with closed back.
CageyH
Quote Reply
Posted: 30 Mar 2020 at 7:14am |
The headphones you mention may be fine. The HD650 are 300 ohm.
I also run HiFiMan Sundara with are around 27 ohm. They also work well with the Solo UL. Can you get a loan of the headphones?
DT999
Quote Reply
Posted: 30 Mar 2020 at 7:57am |
I don't know anyone with the headphones to try, I was just looking at various reviews on line and see that they come in various impedence.
I think the way to go is trial a GSP amp and see how it does with the phones I have, especially if your HiFi Man low impedance work. Thanks again.
Edited by DT999 - 30 Mar 2020 at 10:54am |
patientot
Joined: 28 Nov 2018 Location: USA Status: Offline Points: 1778 |
Quote Reply
Posted: 31 Mar 2020 at 9:38pm |
I have a Reflex M and have tried headphones with it, simply using the cheapo built in headphone jack that is a feature on my integrated amp. No harshness that I could detect using several different cartridges. Now, I'm no expert on headphones, or headphone amps, but I would wager the problem is with the headphones or your amplification source, and has nothing at all to do with the Reflex M.
One thing to keep in mind is that most headphones are not flat. Some have some unpleasant peaks in the frequency response. This is the reason I use EQ when using headphones to listen to digital audio files at my desk. The EQ is built into my software player and I have other EQ programs as well to experiment with. If I were a headphone nut, I'd probably trial one of the GS amps and try to get a pair of headphones that are reputed to match well with them. I'd probably avoid headphones that have a lot of extreme nasty peaks in the audible band.
DT999
Quote Reply
Posted: 01 Apr 2020 at 6:39am |
I agree that it is not the Reflex-M causing the problem, but it is showing up the problem, as you say with either the headphones or amp.
I don't know much about headphones as I only use them as I have to to not disturb the household, I much prefer my speakers. Having said that my speakers cost considerably more than the headphones so maybe to be expected. I do have 2 pairs of headphones, one is planar magnetic and one dynamic and I chose both based on multiple positive reviews in numerous forums so hope they are reasonable - but I accept there will be better and they will have limitations. My headphone amp was chosen to match my amp and for synergy but that may be the problem as alluded to by Graham in his earlier post, that the synergy is not right between the Reflex and my current headphone amp; my original phono stage was also from the same manufacturer as the amp and headphone amp. The Reflex-M still is a VAST improvement over my other phono stage when listening through speakers, which tends to show the main amp is not the issue, but it is the headphone amp.
Ash
Quote Reply
Posted: 01 Apr 2020 at 7:24am |
Post Reply
Page <12345> |
