New Posts New Posts RSS Feed - Headphones from power amp questions
tg [RIP] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Topic: Headphones from power amp questions
    Posted: 07 May 2012 at 4:45am
I have previously seen discussion WRT driving headphones from power amp outputs.
My interest has been sparked by recent acquisition of a rather cute, 2 stage, single valve SET amp with a power output of approximately 2 watts into 8 ohms and I thought to add a headphone out to this.
Which naturally raises a few questions for me
I found a general description at http://sound.westhost.com/project100.htm however, the table of resistor values given does not cover my requirement.
Question 1 - is there a formula readily usable that might yield appropriate values ?
Question 2 - setting appropriate output impedance, particularly for K701, how to determine ?
Question 3 - what effect does varying the output impedance have on heaphone performance in general terms ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 9:44am
DIN standard (IEC1938): 120 Ohms series resistor!
Except most HP manufacturers never heard of standards! They mainly developed their HP's to sound good with their own gear and that's a truth I've learned the hard way the last 13 - 35 years...
mrarroyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrarroyo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 11:06am
I would only use the speaker tabs of a power amp for very special and demanding cans. For now I can only think of:
1. AKG K1000 earspeakers using a pigtail terminated into a 4-Pin balance plug.
2. Stax using one of the many adapter boxes.
3. Something like the HiFiMAN HE6 planar headphone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:41pm
Just to clarify, the intent is not  to drive headphones from speaker terminals.
I headed the topic that way, because in electrical wiring terms that is what is required, but that was not the point of my questions.
The point is to install a headphone jack in the amp by tapping the transformer outputs and reducing them to a suitable level.
The questions were aimed at establishing suitable values for that reduction.
So far, lions 2, heathens nil.
Plan B is SI&S
Edited by tg - 07 May 2012 at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 3:32pm
Tony, the rms output is going to be 4 volts (check sum: 4 squared divided by 8 Ohms = 2 watts).
4 volts is not uncommon for a HPA output before the usual (and advisable) series resistor. I would expect there not to be any DC here (check with meter). Now, if that were the only OPT tap it really should need to switch to a 8 Ohm dummy load (or the amp could "motor-boat"), but if there is a 16 Ohm tap a 16 or 15 Ohm (preferable) dummy load resistor would not have to be rated so high - perhaps a 10 watt wirewound would not get so hot. So, once suitably loaded via a switch to select between speaker and dummy load, then take the HP feed series resistor from there. I suspect a 15 Ohm 1 watt resistor would bring good results with Grado's and K701's.
If this is the wrong answer then please break it to me gently. Embarrassed
An aside: a solid state amp should not need a dummy load resistor normally...
Edited by Graham Slee - 07 May 2012 at 3:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tg [RIP] Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 5:08pm
Thank you Graham,
that is ample guidance for me to proceed with a degree of confidence that I will neither blow up the amp or the cans.
I have let the "magic smoke" out of one device already this week, damn hard to get it back in too.
Heatsinks can be wonderful things. Wink
BTW SI&S = Suck It & See - which can result in the above type of unhappiness.
This page was generated in 0.086 seconds.
