Groove Runner Turntable Speed Control |
Post Reply
Page <12345 6> |
| Author | |
Quote Reply
Posted: 20 Aug 2018 at 1:58am |
For the technically minded here's the block diagram... |
Quote Reply
Posted: 04 Oct 2018 at 8:44pm |
More Groove Runner pictures
![]() ![]() ![]() The supplied universal voltage outboard power supply connects here (100 - 250V AC, 50 - 60 Hz). Rear on/off switch. ![]() Turntable wires to supplied locking plug and plugs in here. Simple 2-wire connection. ![]() 33.1/3 setting for 50Hz turntable motors ![]() 33.1/3 setting for 60Hz turntable motors ![]() 45 rpm setting for 50Hz turntable motors ![]() 45 rpm setting for 60Hz turntable motors |
Quote Reply
Posted: 05 Oct 2018 at 8:15pm |
That looks great Graham. |
Ernie
Joined: 23 Jan 2014 Location: Birmingham UK Status: Offline Points: 430 |
Quote Reply
Posted: 06 Oct 2018 at 6:07pm |
I see it has DAK written on it so I assume it’ll be released as a kit? Looks damn fine Graham, any release date in mind?
ICL1P
Joined: 04 Aug 2012 Location: Faringdon, Oxon Status: Offline Points: 2397 |
Quote Reply
Posted: 06 Oct 2018 at 6:11pm |
This could be a future project for me.
Thanks(1)
Quote Reply
Posted: 06 Oct 2018 at 8:04pm |
As there is a lot of work in preparing it as a kit I thought about offering it ready-built at first. There will be some DIY even with the ready-built unit, that of connecting it to the motor - it will be supplied with a length of 2-core mains cable (of RP3 quality...); the outlet plug; a 4-way terminal block; 0.1uF; 0.12uF; 0.15uF; 0.18uF and 0.22uF mains rated phasing capacitors; 2 x 3.6k resistors to be soldered in parallel for use with the 9904-111-3104 motor (if used). Or if you have a 230V RP3 there is a possibility of only needing to take off the UK plug and soldering on the outlet connector. Mine starts on 33 with output control up full, and to run at 45 start on 33 and when up to speed flick switch to 45.
Quote Reply
Posted: 08 Oct 2018 at 10:06am |
Further details (better description)... The Groove runner is a precision fixed four frequency power supply/drive for belt drive synchronous turntable motors. Plays at the intended speed for when a 50Hz turntable is used on a 60Hz supply, and when a 60Hz turntable is used on a 50Hz supply. Allows you to change from 33.1/3rd rpm to 45 rpm without moving the belt from the 33.1/3rd rpm pulley. Stop position switches off supply to turntable, plus there is a rear panel on-off switch. It outputs 110V because all intended synchronous turntable motors are rated 110V. This allows you to remove power wasting 230V dropper components. In tests it was found to work with an unmodified 230V Rega Planar 3, giving it switched 45 rpm functionality. Output control allows voltage reduction to reduce motor vibration. Output power: 3.6 watts max.; under intended use: <2 watts. Unit is powered by a 15V universal low-voltage outboard DC power supply suitable for all mains voltages and frequencies (100-250V AC; 50/60Hz). DAK brand ready built or in kit form (kit availability to be announced soon). Solderless phasing component kit included with both ready built and kit versions (output cable pre-terminated to output plug on ready built version). Phasing components can be used to replace turntable manufacturers components to reduce motor stress or to enable use of alternative motors. Ready built: £370; kit version: £310. Next post I will discuss the motor phasing kit. |
Post Reply
Page <12345 6> |
