New Posts New Posts RSS Feed - General question about preamps with Proprius amps
DT999 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DT999 Quote  Post ReplyReply Direct Link To This Post Topic: General question about preamps with Proprius amps
    Posted: 18 Jun 2021 at 2:08am
I have recently been considering a change away from my current integrated amp, and to use 2 x Proprius amps to drive my speakers with an appropriate preamp.
Ideally I would love to use an all GSP system and the Majestic as a pre amp, but here is where I run into some difficulties due to the required connections of my system.
I have 2 turntables, one run through an Accession M and the other through a Reflex M.
I also have a CD transport and external DAC. No problem there as I could use the Majestic as the DAC and preamp.
However I also on occasions use headphones and need to connect a headphone amp (looking longer term at the Solo ULDE), which would be connected from the pre-out. But I also have 2 x subwoofers connected in my system, which I currently also run from a pre-out.
So my problem here is that the Majestic only has one analogue line in and one line out; whereas for my system as I currently have it I would need 2 of each.
So my questions are, is there anyway of using a Majestic with my set up as it is?
Or if I look at other preamps, how will they work with the dual Proprius amps?
Should I be looking at active or passive preamps etc?
What other sort of things should I consider?
At this stage I am researching, and I have the opportunity to trial things through the loaner program as I did with the GSP Phono stages, but I need to understand how the system might all go together.
Appreciate your thoughts and insights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 7:34am
I run three turntables with one phonostage (Accession) into my Majestic. I use a switch box from dodocus.de.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 8:15am
...which you could use to extend your inputs.
Ermm I'm working on the rest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DT999 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 10:44am
Thanks, that makes sense.
From your description you obviously run your turntables to the switch and then from switch box to Accession. Do you find the box adds any noise with small cartridge signal or the extra RCA cable length etc. affects anything?
I could run both of my phono stages to a switch box, but doing it your way mans I can remove a box (and even sell on the Reflex to offset costs)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DT999 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 10:45am
Thanks Graham, it will be interesting to see if there is a work around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICL1P Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 1:50pm
I’ve not noticed any detrimental effect. The Dodocus box I have (Model 248) is designed for this purpose. Best to check with Konrad.
Sylvain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sylvain Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2021 at 2:54pm
This issue is also my endeavours for last 12 months  with Two Thorens but saw a QED switch box at Richer Sounds .....but will wait for further from Graham.....
I use Proprious Mono's and had harassed Graham on a Passive Pre Amp and mine is ready with a Good Potentiometer in a  Box .....The Proprius is parked as advised on literature and my DAC electronic Pre amp is good but temperamental and 46 clicks resistors in a box add to noise but in ' shunt' design barely noticeable provided low K.
Electronic Pre amp with CD' output of 2.8 V cause me to opt for a separate passive.
