New Posts New Posts RSS Feed - Solo Ultra Linear DIY upgrade
wadiaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wadiaman Quote  Post ReplyReply Direct Link To This Post Topic: Solo Ultra Linear DIY upgrade
    Posted: 06 Jul 2010 at 12:18pm
I believe that I am the first to buy the Solo Ultra Linear DIY upgrade and as such I would like to report how this turned out.
I ordered this via the online shop which was very easy to negotiate,in fact one of the best shops of this variety I have used,very slick ! The upgrade is in fact a completely new PCB which arrived just over a week later by UPS,I was given notice of dispatch with a tracking number by e-mail,all very reassuring.
The DIY aspect of this upgrade is pretty straightforward and is simply a matter of swapping over the UL PCB withe existing board,this is how that was done.
First off I connected my earth cable to my watch strap (a length of wire connected to a bared radiator pipe one end and the other with a croc' clip fitted under the watch strap),I do seem to be a collector of static so a necessary precaution !
Dealing with the front panel of the Solo the volume knob was removed by loosening the small grub screw and then the nut securing the pot to the front panel was undone.Next the 4 small countersunk screws were removed using a 2mm hex key.This enables the front panel to be now removed and after removing the 4 similar screws on the rear panel the entire PCB together with the rear panel can now be slid rearwards out of the casing.
The rear panel now needs to be removed from the PCB,firstly the small black self tapping screw in the centre of the RCA connector panel is removed and then the grounding post needs to be disconnected.
This was in fact the only fiddly bit in the whole operation as when undoing the nut securing the post, the screw itself turned as well,it was obviously necessary to hold the screw from the PCB side but there was not enough room for a conventional Philips screwdriver.After a search through the toolbox I unearthed my "right-angled" screwdriver with a flat blade one end and a Philips drive the other,this fitted nicely in the space and the nut was removed and the screw taken out of the tag on the end of the ground wire of the PCB ,the rear panel was then removed from the PCB.
Fitting the new UL PCB is essentially the reverse of the above,however some care needs to be taken to align the rear panel over the RCA input sockets,also the ground wire on the new board needs to be re-connected via the screw removed above to make the ground post this being secured by the nut on the outside of the panel.This assembly is then slid back into the casing using the lowest grooves in the case sides to locate the PCB and the 8 screws are replaced in the front and rear panels.Last job is to secure the volume pot to the front panel with the large washer and nut,take care not to overtighten,just nip it up,same goes for the end panel screws.
So there we are,"the job's a goodun'",all in it took about 20 minutes,if anyone has any doubts there really is nothing that is too difficult,if you can change a 13 amp plug, you can do this upgrade !
The great thing is of course is that this is all made here in sunny Yorkshire so if there are any snags the designer and manufacturer is just a phone call or an email away !
I will report later on how the new Solo UL performs,at the moment it is burning in 24/7 via an FM tuner on Classic FM,I'll give it an initial 100 hours and see how it sounds then.
hotmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotmog Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 6:31pm
Good stuff! I have to admit I didn't even realise that the UL upgrade was now available as a DIY option - serves me right for not looking Ermm; I sent my Solo MC back to Graham only yesterday for that upgrade. Given my track record for repairing delicate electro-mechanical items (ie my turntable), however, maybe that's just as well Wink.
mrarroyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrarroyo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 12:48am
wadiaman, look forward to your impressions. Enjoy your new toy.
Francisco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Francisco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 9:22pm
Wadiaman! Welcome to the Ultra-Linear club Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 1:00am
Well done wadiaman! You got there before I could publish the instructions.
They're now online at http://www.diy-audio-kits.com/kits/diysoloultralinearheadphoneampupgrade.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotmog Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 10:33am
Just out of curiosity, are the photos in that link of the actual Ultra Linear PCB, or is it an SRGII being used for illustrative purposes? I only ask because there is another thread about the UL that shows the entire PCB being coated in some sort of epoxy dip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 1:22pm
The photos of the upgraded Solo (see stage 10 onwards and the heading photo) are the Ultra Linear board. The lighter coloured board is the customer's original 2006 model (one we did here).
The early module was covered in a white epoxy dip but the new module is the encapsulated lump stood off the Solo Ultra Linear board.
I'm sure there will be questions as to what's inside the encapsulated module and my reply is two op-amps, some resistors and a capacitor which make the op-amps emulate the open loop gain of a valve.
The other "secrets" are on the board un-disguised but without knowing what the module does it is impossible to understand. In a nutshell these component values adjust the input linearity so that the combination of the module and the component values makes the Solo emulate the input linearity of a valve.
There are some other little dodges because to emulate a valve is not a single trick - the output stages of the op-amps are chosen for their similar behaviour to the research started by Williamson (of ultra-linear valve amp fame).
Edited by Graham Slee - 09 Jul 2010 at 3:06pm
