New Posts New Posts RSS Feed - Accession M
Accession M
robbiec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robbiec Quote  Post ReplyReply Direct Link To This Post Topic: Accession M
    Posted: 01 May 2025 at 4:18pm
So I am almost at the stage where I am fully Slee'd or Cadman'd with my Rega 2 & Exact feeding into my freshly arrived (11:02 this morning) Accession M which in turn feeds into a Majestic where I can chose between a Solo and Focal Elegia or a pair of Proprius into a pair of Focal Aria 906s. The Exact has a capacitance or either 97pF or 100pF depending on where you read so I flicked the 100pF setting down on left and right and plugged in the PSU1 which had previously powered a Gram Amp SE and I walked away for a couple of hours.
PJ Harvey - To Bring You My Love (is this a classic now at 30 years old?)
Needle dropped and I sat down. Oh Wow! It's an unveiling of more! more detail, more presence, just more of everything good - more than I expected actually. Very happy camper! It felt like Polly Jean was in the room, off to the right a little :)
I have some Lautus and Libran on order and short of 3 Enigma's I think i'm done system wise!
Hang on tightly, let go lightly.
Voyager x 2 | Bitzie | Accession M | Solo ULDE | Enigma | PSU1 x 2 | Proprius x 2 | Majestic | Rega Planar 2 & Exact | Focal Aria & Elegia | Libran | Lautus | Spatia
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 8:39am
Great review. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robbiec Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 6:18pm
I probably jumped the gun a bit and will expand after a month or so. Next steps will some Lautus and then Enigma's but seriously happy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 6:59pm
I thought it was a good review and look forward to hearing more about what you're hearing.
This page was generated in 0.077 seconds.
