New Posts New Posts RSS Feed - PSU1 is 13 amp fuse ok?
Nunnother View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nunnother Quote  Post ReplyReply Direct Link To This Post Topic: PSU1 is 13 amp fuse ok?
    Posted: 07 Jan 2020 at 7:27am
I have recently purchased a GS Solo Ultra Linear DE with PSU1 power supply.  The supplied power lead appears to have a 3 amp fuse.  Looking at new audiophile power leads most of them contain 13 amp fuses.  This is probably a daft question but is it ok to use a power lead that contains a 13 amp fuse with the PSU1 and GS Solo Ultra Linear DE?
sheepskinstu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sheepskinstu Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2020 at 9:40am
I thought 13amp fuses were used in washing machines and kettles! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2020 at 11:05am
I'd be inclined to stick with the recommended fuse rating, it's there to protect the cable, equipment and you. Many devices have their own internal fuses designed more specifically for the circuits they protect. Only monstrous power amplifiers might justify 13A fuses, which at 240V are appropriate for power ratings of up to 3kW!, ie kettles and the like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 7:52am
You can use the 13A fuse but it won't offer the PSU1 any protection against excessive current draw. Isn't the max or standard draw current in the range of 200mA? Component damage would occur long before the fuse filament melts to break the circuit. I think the PSU1 has internal protection as well though. Thermal cutoff?
Can the fuses be swapped?
Edited by Ash - 08 Jan 2020 at 7:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nunnother Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:32pm
Thanks for the replies.  I've decided to buy some AMR 3 amp fuses which I will use with the lead to my PSU1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 8:05pm
"Lead us not into temptation..."Thumbs Down
John C View Drop Down
gspaudio moderator
Post Options Post Options   Thanks (0) Thanks(0)   Quote John C Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 10:13am
Is this an ROHS related joke?
This page was generated in 0.074 seconds.
