New Posts New Posts RSS Feed - DC components
DC components
Sylvain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sylvain Quote  Post ReplyReply Direct Link To This Post Topic: DC components
    Posted: 25 Aug 2013 at 10:52pm
Mr G Slee
I seek you here as I could not identify your further elaborations on our previous string discussion.
Some designers  say that avoiding capacitors and resistors along the signal path is useful to maintain signal purity...the technique they advocate is DC Coupling ad DC servo assisted ...
Can you assist me understand the concept application...please Sir!!!!Tongue
Thank you
S Jacques
Post Options Post Options   Thanks (1) Thanks(1)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 11:46pm
See http://audio-forum.gspaudio.co.uk/phono-preamp-pt2-mc_topic1459_page7.html
 the servo application is discussed here by Graham.
It is definately not as good as a properly designed single supply, capacitively coupled, preamp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 12:28am
Thanks Bruce, you have saved us from repeating the thread and answered Sylvain's enquiry.
It's limited compared to Graham and others here but my practical experience of working on and listening to DC coupled circuits suggests it is a lot of extra complexity when a carefully chosen capacitor will achieve the same end. The excellent sound quality of the GSP gear is pretty persuasive on the merits of the latter approach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sylvain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 1:01pm
Thank you all ....I truly and sincerely appreciate.
Sylvain J TTongue
This page was generated in 0.074 seconds.
