New Posts New Posts RSS Feed - Cusat50 cinch cable
Cusat50 cinch cable
dc2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dc2 Quote  Post ReplyReply Direct Link To This Post Topic: Cusat50 cinch cable
    Posted: 23 Mar 2008 at 6:04pm
I have recently purchase 2 off 1m CuSat50 cables from JohnC.
The cable was offered in 0.5m increments starting off at 0.5m.
They were packaged in a heavy duty cardboard wallet and the plugs were protected with foam wrapping.
The interconnect is very well built and finished. Overall black braid hold the two lengths of copper satallite cable together. The locking phono plugs grip fast to the sockets and are not likely to slip or loosen. The centre pin is split to give a tight contact when the plug is inserted.
I have owned cable with phono plugs that either need excess force to make or slip out of the socket with the weight of the cable. You will not have these problems with the CuSat50.
The cable is clearly marked for direct, following the print on the cable sheath.
My first thoughts were that the cable was built - fit-for-purpose.
For the money outlay I have purchased quality materials selected and built by JohnC to an excellent standard.
Thanks JohnC, you have a very satisfied customer.
Cyreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyreg Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2008 at 10:25pm
Hi DC, let us know how they sound when they have bedded in.
Did you twirle and twist them or left just the way they are?
Maybe a comparison with another known IC is possible? Thanks Han
TecnoDec/RB250/MP110>GramAmp2C/PSU1; Cyrus CD8SE; > Exposure 3010S2D INT > Harbeth C7ES-3 '35th Anniversary'
cabling: IC 2x DNM V3; LScable Exposure DMF-two; Furu TP60 + MWaY and BlackCable pc's
dc2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dc2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2008 at 12:14am
Hello Cyreg,
With regards to the cable twirling,
NO twirling round my head, just plugged them straight in.
If I read other comments correctly the twirling is to loosen the hold the outer sheath has over the copper screen braid.
I don't know how effective this would be as the two cables are heatshrinked together with an overall PVC braid so not much play once the cable is finished (maybe JohnC done the twirling during the process of building them?)
I have some DNM cable without the Eichmann plugs. I will do an A-B comparison with these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyreg Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2008 at 7:43pm
@dc, did you compare the 2 cables? and.........?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 9:48pm
I have borrowed a pair of 1.5m Cusat cables and compared them to a number of 1m phono leads (no names), including my homemade leads (premium satellite cable i.e. OFC braided screen coax). I used my CD player with DAC and a Reflex M, rock pop and classical albums.
The sound quality is excellent on the Cusat cables, I could hear every part of the sound clearly. It was full bodied, detailed and very easy to listen to. The positioning of instruments and sounds is precise but above all it is a really natural clear soundfield.
The construction of the cables and phono plugs is first rate. The plugs are the most solid and functional I have seen, including a clamping mechanism to lock onto the sockets and give a perfect electrical connection.
Definitely the best phono cables I have used and heard. I will have to start saving up...
Dave Friday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Friday Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2012 at 2:29pm
hi,I typed a review but it was'nt accepted[they are clearer than my cheap cables!]
so will see if this comes out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackinBlack Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2012 at 6:09pm
Hi Dave,
I found that if you wait or type for too long then the message/reply box times out. So for longer insertions it might be better to compose it in word or notepad &c, then copy and paste into the message box.
Hope you succeed as I should like to hear your review.
This page was generated in 0.076 seconds.
