New Posts New Posts RSS Feed - Fidelity Audio Upgrade for Novo
cattle prod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cattle prod Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 8:57am
I wish I had the brass neck! (not)Must be all of £5 quids worth, or more like £2 if you're trade!My advice: spend less than that on a year's subscription of the upcoming Audio Projects magazine - it'll tell you how to do real tweaks that work, and how they work too!Yes, you too can be a hot modding expert and get 6 or 12 times the value for 30% less than this rip!
More info on Audio Projects magazine would be nice. Is this one of yours?
Edited by cattle prod - 09 Mar 2010 at 8:57am
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:00pm
Yes Big%20smile
Eventually...Confused
(I think I may have taken on too much for the beginning of the year so it isn't imminent)
Jitter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jitter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 1:20am
I'm not inclined to make modifications to newer equipment.  I have modified a Quad 303 power amp and an old Rotel CD player.  For me the reason for modifying is if better components are available.  I don't see why you would buy a piece of kit which wasn't manufactured with with quality of components you wanted.
Consequently, Graham - I wouldn't worry
...... and that's my opinion, take or leave it
