New Posts New Posts RSS Feed - DIY Novo problem
DIY Novo problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 7:23pm
Originally posted by Kevb Kevb wrote:
Thanks for the responses Gents. By re-soldering the junction John- do you mean have a go at all the components joints?
Thanks once again
Yes.
Based on Graham's expert advice I would start with the capacitors.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ash Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2022 at 7:56pm
A dry joint is held in place by flux rather than solder. A well-soldered joint uses the minimum solder to achieve a firm connection that usually has a shallow cone shape and cannot be wiggled.
Kevb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevb Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 8:49pm
Thanks one and all for your support on this,much appreciated. Quick update I got the soldering iron out and ran over all the joints, but to no avail.
I have for a long time wanted to try the communicator pre-amp and thanks to John C i have got hold of a loan unit (fantastic scheme BTW).
Low and behold all buzzing disappeared!! . Guess it was some kind of cable cross talk or the like. So on to the Genera I think !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lfc jon Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 10:29am
Glad to hear you got it all sorted enjoy.
