DIY Novo problem |
Post Reply
Page <12 |
| Author | |
Quote Reply
Posted: 23 Feb 2022 at 7:23pm |
Yes. Based on Graham's expert advice I would start with the capacitors. |
Ash
Thanks(1)
Quote Reply
Posted: 23 Feb 2022 at 7:56pm |
A dry joint is held in place by flux rather than solder. A well-soldered joint uses the minimum solder to achieve a firm connection that usually has a shallow cone shape and cannot be wiggled.
Kevb
Quote Reply
Posted: 26 Mar 2022 at 8:49pm |
Thanks one and all for your support on this,much appreciated. Quick update I got the soldering iron out and ran over all the joints, but to no avail.
I have for a long time wanted to try the communicator pre-amp and thanks to John C i have got hold of a loan unit (fantastic scheme BTW). Low and behold all buzzing disappeared!! . Guess it was some kind of cable cross talk or the like. So on to the Genera I think !!!! |
lfc jon
Joined: 23 Jan 2018 Location: Devon Status: Offline Points: 4353 |
Quote Reply
Posted: 27 Mar 2022 at 10:29am |
Glad to hear you got it all sorted enjoy.
Post Reply
Page <12 |
