New Posts New Posts RSS Feed - Cleaning Hi Fi Systems
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning Hi Fi Systems
    Posted: 21 Jun 2008 at 8:23am
One problem I have is dusting my system as it is rack mounted.
I have found a reasonable solution, it is a "Pledge - Fluffy Duster ". It is a fluffy duster ( Yup ! ) on an extending plastic handle that fits under most of the equipment on racks, and can be assisted by lifting equipment at the edges !!
The fluffy duster ( apologies about this ! ) attracts dust and allergens. They are also only a couple of quid!
Adrian.
WhaleBlue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhaleBlue Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2008 at 9:49pm
I use a micro-fibre duster wrapped around a 30cm plastic ruler
Hang on. What am I doing? Blokes, discussing cleaning tips?
Darren/Audio Elevati View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darren/Audio Elevati Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2008 at 1:26pm
I'm a closet user of the Pledge fluffy duster too.  Oh no, outed by a forum.
Chivas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chivas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2009 at 8:06am
My equipment is also rack mounted, 6 layers and for some reason all the dust in the world seems to be attracted to my equipment. When it comes to my audio gear, I believe I may suffer from a mild to severe case of OCD, so found myseld dusting every single day, this is both time consuming and I aso fear scratching, so have resorted to pressurised air, usually used for PC's, bought from Maplin. Not sure if this could be damaging, but obviously dont use it when my equipment is hot or directly into air vents and so far so good
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhaleBlue Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2009 at 3:54pm
You need help, my friend
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chivas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2009 at 10:40pm
You think...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham Slee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2009 at 1:29am
Do you mean he needs to get a cleaner to come in twice a week? ............................
LOL
This page was generated in 0.088 seconds.
