New Posts New Posts RSS Feed - Choosing a UPS
Choosing a UPS
peterb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterb Quote  Post ReplyReply Direct Link To This Post Topic: Choosing a UPS
    Posted: 03 May 2024 at 11:38am
Does anyone have any experience of their HiFi supplied by a UPS?
Our mains supply fails a couple of times a year, wind and overhead cable problems mostly, and it causes havoc with my HiFi. I think if it was just a clean break it would be OK but too often it is rapid on/offs before it goes off completely.
The Preamp load is not great even when on so the UPS does not need to be a large expensive one, and I am not trying to protect the Power Amp when it is on.
Thanks
Dual 505-1, Cyrus CD T, DIY 80W MosFet amp and PreAmp, 2xKEF 103.2
CageyH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 5:38pm
I started to look at one, and was after a pure sine wave version, and that really bumps the price up, so I did not go any further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterb Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 10:33am
I know a little about their design; a battery, some Mains detection circuitry, DC to AC conversion electronics and a power output stage.
If the Mains detection system just let the UPS supply when it sensed a Mains issue and otherwise let the load be Mains fed until then, that would work for me. But I think they become to only source of power for the load.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 10:42am
The other issue is getting a model that allows sufficient peak power for your power amplifier.
It depends how sensitive your equipment is as to which would be best.
Something like a 1500VA should be ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterb Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 6:45pm
OK I have taken the plunge with this one.
I am not expecting to keep the Pre and Amp running, I just want to protect the Pre from spikes so a low power requirement, in standby.
My choice is a model which only supplies the load when the Mains is outside the trigger parameters so is not supplying in 'normal' conditions.
If it ruins the sound I will use it to protect my NAS. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 6:49pm
That should give you plenty of time to power the system down in the event of a.power cut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 11:54am
A quick update. To my ears the UPS is not audible when I am using my setup, which is as it should be as it is not part of the supply.
I have had the Mains circuit trip since it was put in when I was trying to wire a replacement cellar light where the previous owner had used the socket circuit and blacks as live ! The UPS did its job and stopped the corruption of my PreAmp firmware, so as far as I am concerned a worthwhile investment.
This page was generated in 0.096 seconds.
