New Posts New Posts RSS Feed - Can I switch the PSU1 power cable?
DanceWalker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanceWalker Quote  Post ReplyReply Direct Link To This Post Topic: Can I switch the PSU1 power cable?
    Posted: 01 May 2024 at 7:30pm
Hi community,
I recently bought a solo ultra linear which came with the psu1 power supply from someone who lives in Australia. I live in the UK. When it arrives the PSU1 will have an Australian plug. What can I do?
Like I said I will be using it in the UK, so need to plug it in here. Thanks 😊
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:41pm
Please send a PM to John_C.
Ernie View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ernie Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 12:16am
Buy any figure of 8 cable or chop the Australian plug off and fit a British one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanceWalker Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 12:38am
Figure of 8 cable does not look right. Is it supposed to be something like this https://www.russandrews.com/slee-link-dc-cable-3-pin-din-to-25mm/#:~:text=The%20DC%20link%20cable%20is,a%202.5mm%20power%20socket. ;
It says dc cable 3 pin. I'm new don't know much about these things.
Edited by DanceWalker - 02 May 2024 at 12:38am
CageyH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 9:55am
You need to change the cable going from the wall socket to the PSU.
The one from the PSU to the equipment will be fine.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CageyH Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 9:57am
This page was generated in 0.060 seconds.
