New Posts New Posts RSS Feed - Arcam Delta 290 help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BAK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 4:38pm
Could you use the Rega Brio integrated while you send out the Arcam D290 for a good cleaning?
 From what I see in the Arcam D290 service manual, it uses a remote controlled motor on the input selector rotary switch... very interesting design. That switch may just need a good cleaning.
Also, depending on your serial #, Arcam made some circuit changes for amplifier stability improvements.
less View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote less Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 5:09pm
should you require a second 290P I could do you one very reasonably Wink
