Voyager Volume Problem |
Post Reply | Page 12> |
KenWilson
New Member Joined: 07 Aug 2011 Location: Scotland Status: Offline Points: 20 |
Posted: 09 Apr 2013 at 11:11pm |
Hi Graham,
Tried sending you an email but got a bounce back, so had to post on the forum. I was just checking if you did repairs? I have a one of your Voyager amps which I've been successfully and happily using for a number of years now. Unfortunately it has developed a volume related problem. It started a couple of weeks ago now. While adjusting the volume I notice it crackling and the sound became very loud and abrasive. However having tried it again at the weekend there is now almost no sound coming out of my headphones. I'd hate to think it was un-repairable, as I use that and my Ultra Linear on a very regular basis. Can you let me know if it's fixable please? Thanks in advance, Ken Wilson
Ash
Graham will get back to you soon, because he cares a lot about his customers. He's been busy lately with the move of his headquarters so he has not been around here as much as he would like. Sit tight and he'll respond eventually.
Sounds like some sort of component failure/fault perhaps, even if it's just one single component. I'm sure it is straightforward enough to fix, even if it involves one of Graham's guys taking a look at the PCB and replacing an electronic component. |
mrarroyo
Moderator Group Joined: 28 Jul 2008 Location: Miami Beach, FL Status: Offline Points: 1401 |
Ken, I sure hope you get your Voyager fixed soon. It is a very nice sounding amp and it should not be any problem for Graham to correct the situation. Cheers!
KenWilson
Thanks for responding so quickly, much appreciated. Like you, I'm hopeful that it can be fixed.
Cheers,
Ken
JamesD
Senior Member Joined: 05 Nov 2012 Location: Bolsover Status: Offline Points: 246 |
Maybe something as simple as a rogue dry joint, I say rogue because of the usual high build quality!
Ash
Remember that Graham does not build individual electronic components so he is dependent on the components he receives from his suppliers. I personally doubt the build quality has anything to do with it. Perhaps it does but I doubt it. It's probably simply a component failure, which is not GSP's fault as they have no control over the expected lifespan of the electronic components that they use. GSP HQ has plenty of electronic test equipment for identifying a fault on a PCB. It will simply be a sequence of elimination via test apparatus until they isolate the problem. Component replacement will solve the issue, I'm sure. No need to be too concerned and I'd imagine repair costs won't be too bad.
I did reply but it seems it didn't get through. Been busy trying to manage new workshop fitting out - great tradesmen this time around but asking lots more questions than I can answer - hoping to be back to posting soon.
DC offset can cause "pot scratch" but high frequency instability is the usual culprit and is why we fit compensation capacitors. If an older unit it may not have them because the design tested stable, but I'm now doing "belt and bracers" because the airwaves are so over modulated these days. If it does have comp caps one could fail but if on both channels two failed caps are highly unlikely. Is the input cable shielded? If you're unsure give us a call on 01909 568739 (+44 prefix outside UK) |
