New Posts New Posts RSS Feed - Vinyl cleaning machines
Footballcube View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Footballcube Quote  Post ReplyReply Direct Link To This Post Topic: Vinyl cleaning machines
    Posted: 05 Oct 2022 at 8:52am
Looking to clean up my old 12" LPs from 70s until present day.
With no local service near me any feedback and suggestions welcome for purchasing a cleaning machine particularly suction type cleaners and ultrasonic variants.  Have around 400 LPs and budget around £400 ish.
Thanks
Mikeh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeh Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 3:53pm
I bought my Moth RCM secondhand from Steve on this Forum. A good machine, built like a tank which does a good job but is v noisy. I don't knowwthat there's much difference in results from RCMs, they all work on the same process it's a matter of build quality vs price.
There is a new ultrasonic cleaning machine started selling direct from Hong Kong at a reasonable price. Seems to get pretty good feedback from owners on other forums. Might be worth looking up HumminGuru.  I have no direct experience with ultrasonic cleaners.
Technics sl1210g with Victor U-2
Cambridge Audio CXC CD player
Lindemann Limetree Bridge streamer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Footballcube Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 4:52pm
Thanks Mike I will check out both the Moth and Humminguru RCMs.
Need to also consider the on going spares availability as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatmangolf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 6:12pm
£400 should get you a good brush and suck machine. Okki Nokki, Prxjxct, etc.
Edited by Fatmangolf - 08 Oct 2022 at 5:22pm
RichW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichW Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 11:24am
I've used the Moth RCM for many years and recommend it. I use it with Moth RCM fluid.
The supplied domestic brush was recently replaced with an Analogue Studio goat's hair brush
and this is recommended.
A machine like this is far better than cleaners that use a bath of fluid & brushes but do not
vacuum.
patientot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patientot Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2022 at 9:24pm
Been using a vac-based machine for years. Will probably try ultrasonic at some point. I've had some US-cleaned LPs from a few sellers before and they were very quiet in the groove.
Bi-wire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bi-wire Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 2:39pm
I moved away from the vac-based approach when my Okki Nokki went wrong and couldn't get it sorted out. I bought an ultrasonic cleaner and feel that it gets equally good results  -  possibly better  -  and is quieter. It is also quicker as it can handle six records at a time, but the one drawback is that it doesn't dry the record after cleaning. I leave them on the machine spindle standing vertically on a towel and turn them occasionally to dry 'naturally'. All-in-all, I prefer the ultrasonic machine.
My machine is an ARC-02 bought from: audiorevita.com
